DWG Destroyer Posted August 20, 2009 Posted August 20, 2009 When a closed polyline is selected via a double click, the polyline edit dialogue will engage. If the "open" option is selected, the polyline will open up by erasing one of its lines, seemingly at random. But what if in some way the selection of the line to be erased could be controlled? It would prove most useful if I could double click a polyline and once "open" is selected, the polyline opens on the line I double clicked on. A possibility or just banter? Quote
NBC Posted August 20, 2009 Posted August 20, 2009 I have no solution to your query; but just wanted to say that 'erasing of one line', when opening a closed pline is not random. It will always open at the place where the pline was closed. Quote
Lee Mac Posted August 20, 2009 Posted August 20, 2009 As a shortcut to what you were doing: (defun c:PlOpen (/ ent Obj) (vl-load-com) (if (and (setq ent (entsel "\nSelect LWPolyline: ")) (eq "AcDbPolyline" (vla-get-ObjectName (setq Obj (vlax-ename->vla-object (car ent)))))) (vla-put-Closed Obj :vlax-false)) (princ)) Quote
Lee Mac Posted August 20, 2009 Posted August 20, 2009 Try this Mr Destroyer, will only work on Polylines with no Arcs and funny stuff. [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:PlOpen [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ent Obj pPar pCrds[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect LWPolyline: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"AcDbPolyline"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ObjectName[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [color=Blue][b]:vlax-true[/b][/color] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Closed[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pPar [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]fix[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getParamatPoint[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getClosestPointto[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pCrds [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b]remake-list [b][color=RED]([/color][/b]vlax-list->2D-point [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray->list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-variant-value[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Coordinates[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] pPar[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-put-Coordinates[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-variant[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray-fill[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-safearray[/color][/b] [color=Blue][b]vlax-vbdouble[/b][/color] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1-[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]length[/color][/b] pCrds[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] pCrds[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-put-closed[/color][/b] Obj [b][color=Blue]:vlax-false[/color][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** LWPolyline not Closed **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Object Not an LWPolyline **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] vlax-list->2D-point [b][color=RED]([/color][/b]lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]vlax-list->2D-point [b][color=RED]([/color][/b][b][color=BLUE]cddr[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Remake-List [b][color=RED]([/color][/b]lst i [color=Blue][b]/[/b][/color] j k[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] j [b][color=#009900]-1[/color][/b] k [b][color=#009900]-1[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] j [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] j[b][color=RED])[/color][/b][b][color=RED])[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]>=[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] k [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] k[b][color=RED])[/color][/b][b][color=RED])[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
DWG Destroyer Posted August 20, 2009 Author Posted August 20, 2009 Hey, not bad! But is there a way to incorporate this into the collection of options within the edit polyline command? Along with open/ join/ width etc.? It would be cool if i could get all this just from a simple double click of a polyline. Quote
Lee Mac Posted August 20, 2009 Posted August 20, 2009 Hey, not bad! But is there a way to incorporate this into the collection of options within the edit polyline command? Along with open/ join/ width etc.? It would be cool if i could get all this just from a simple double click of a polyline. haha, you'll be lucky... I doubt you can edit AutoCAD commands like that... :wink: Quote
Lee Mac Posted August 20, 2009 Posted August 20, 2009 Here is an upgrade that should allow arcs in Polylines: [i][color=#990099];; Open Polylines at Selected Edge[/color][/i] [i][color=#990099];; Copyright © 2009 Lee McDonnell ~ 20.08.2009[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:PlOpen [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ent Obj pPar pCrds lst Blg i[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] doc [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-acad-object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect LWPolyline: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"AcDbPolyline"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ObjectName[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [color=Blue][b]:vlax-true[/b][/color] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Closed[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-StartUndoMark[/color][/b] doc[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pPar [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]fix[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getParamatPoint[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getClosestPointto[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pCrds [b][color=RED]([/color][/b]vlax-list->2D-point [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray->list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-variant-value[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Coordinates[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]fix[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getStartParam[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] i [b][color=#009900]-1[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]repeat[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1-[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]length[/color][/b] pCrds[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Blg [b][color=RED]([/color][/b]remake-list [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-getBulge[/color][/b] Obj x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] pPar[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-put-Coordinates[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-variant[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray-fill[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-safearray[/color][/b] [color=Blue][b]vlax-vbdouble[/b][/color] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1-[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]length[/color][/b] pCrds[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b]remake-list pCrds pPar[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-setBulge[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] i [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Blg[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-put-closed[/color][/b] Obj [b][color=Blue]:vlax-false[/color][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-EndUndoMark[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** LWPolyline not Closed **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Object Not an LWPolyline **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] vlax-list->2D-point [b][color=RED]([/color][/b]lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]vlax-list->2D-point [b][color=RED]([/color][/b][b][color=BLUE]cddr[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Remake-List [b][color=RED]([/color][/b]lst i [b][color=BLUE]/[/color][/b] j k[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] j [b][color=#009900]-1[/color][/b] k [b][color=#009900]-1[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] j [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] j[b][color=RED])[/color][/b][b][color=RED])[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]>=[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] k [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] k[b][color=RED])[/color][/b][b][color=RED])[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
alanjt Posted August 20, 2009 Posted August 20, 2009 pretty slick Here is an upgrade that should allow arcs in Polylines: [i][color=#990099];; Open Polylines at Selected Edge[/color][/i] [i][color=#990099];; Copyright © 2009 Lee McDonnell ~ 20.08.2009[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:PlOpen [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ent Obj pPar pCrds lst Blg i[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] doc [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-acad-object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect LWPolyline: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"AcDbPolyline"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ObjectName[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [color=Blue][b]:vlax-true[/b][/color] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Closed[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-StartUndoMark[/color][/b] doc[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pPar [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]fix[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getParamatPoint[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getClosestPointto[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pCrds [b][color=RED]([/color][/b]vlax-list->2D-point [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray->list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-variant-value[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Coordinates[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]fix[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getStartParam[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] i [b][color=#009900]-1[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]repeat[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1-[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]length[/color][/b] pCrds[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Blg [b][color=RED]([/color][/b]remake-list [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-getBulge[/color][/b] Obj x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] pPar[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-put-Coordinates[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-variant[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray-fill[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-safearray[/color][/b] [color=Blue][b]vlax-vbdouble[/b][/color] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1-[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]length[/color][/b] pCrds[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b]remake-list pCrds pPar[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-setBulge[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] i [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Blg[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-put-closed[/color][/b] Obj [b][color=Blue]:vlax-false[/color][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-EndUndoMark[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** LWPolyline not Closed **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Object Not an LWPolyline **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] vlax-list->2D-point [b][color=RED]([/color][/b]lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]vlax-list->2D-point [b][color=RED]([/color][/b][b][color=BLUE]cddr[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Remake-List [b][color=RED]([/color][/b]lst i [b][color=BLUE]/[/color][/b] j k[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] j [b][color=#009900]-1[/color][/b] k [b][color=#009900]-1[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] j [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] j[b][color=RED])[/color][/b][b][color=RED])[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]>=[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] k [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] k[b][color=RED])[/color][/b][b][color=RED])[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
DWG Destroyer Posted August 20, 2009 Author Posted August 20, 2009 Ah well not to worry. Hey it even remembers what type of line was removed when you close it again! Top stuff, thanks! Quote
Lee Mac Posted August 20, 2009 Posted August 20, 2009 pretty slick Thanks dude Ah well not to worry. Hey it even remembers what type of line was removed when you close it again! Top stuff, thanks! Yes - due to the Bulge value set at the specific vertex :wink: Quote
Lee Mac Posted August 20, 2009 Posted August 20, 2009 Finally, this should deal with varying polyline width: [i][color=#990099];; Open Polylines at Selected Edge[/color][/i] [i][color=#990099];; Copyright © 2009 Lee McDonnell ~ 20.08.2009[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:PlOpen [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] doc ent Obj pPar pCrds lst Blg i Wid st en[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] doc [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-acad-object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect LWPolyline: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"AcDbPolyline"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ObjectName[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [color=Blue][b]:vlax-true[/b][/color] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Closed[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-StartUndoMark[/color][/b] doc[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pPar [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]fix[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getParamatPoint[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getClosestPointto[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pCrds [b][color=RED]([/color][/b]vlax-list->2D-point [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray->list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-variant-value[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Coordinates[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]fix[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getStartParam[/color][/b] Obj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] i [b][color=#009900]-1[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]repeat[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1-[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]length[/color][/b] pCrds[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Blg [b][color=RED]([/color][/b]remake-list [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-getBulge[/color][/b] Obj x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] pPar[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] x [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b] lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-getWidth[/color][/b] Obj x [b][color=DARKRED]'[/color][/b]st [b][color=DARKRED]'[/color][/b]en[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Wid [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] st en[b][color=RED])[/color][/b] Wid[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Wid [b][color=RED]([/color][/b]remake-list [b][color=RED]([/color][/b][b][color=BLUE]reverse[/color][/b] Wid[b][color=RED])[/color][/b] pPar[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-put-Coordinates[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-variant[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray-fill[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-safearray[/color][/b] [color=Blue][b]vlax-vbdouble[/b][/color] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1-[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]length[/color][/b] pCrds[b][color=RED])[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b]remake-list pCrds pPar[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x y[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-setBulge[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] i [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b] x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-SetWidth[/color][/b] Obj i [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] y[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] y[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Blg Wid[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-put-closed[/color][/b] Obj [b][color=Blue]:vlax-false[/color][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-EndUndoMark[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** LWPolyline not Closed **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Object Not an LWPolyline **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] vlax-list->2D-point [b][color=RED]([/color][/b]lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]vlax-list->2D-point [b][color=RED]([/color][/b][b][color=BLUE]cddr[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Remake-List [b][color=RED]([/color][/b]lst i [b][color=BLUE]/[/color][/b] j k[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] j [b][color=#009900]-1[/color][/b] k [b][color=#009900]-1[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] j [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] j[b][color=RED])[/color][/b][b][color=RED])[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]>=[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] k [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] k[b][color=RED])[/color][/b][b][color=RED])[/color][/b] i[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
DWG Destroyer Posted August 20, 2009 Author Posted August 20, 2009 And it does! Much appreciated. Quote
Lee Mac Posted August 20, 2009 Posted August 20, 2009 And it does! Much appreciated. Not a problem - I had fun making it Quote
alanjt Posted August 21, 2009 Posted August 21, 2009 i wasn't thinking about it earlier, but what's the difference in using this and just using trim? pick the pline, pick the segment in the pline. Quote
Lee Mac Posted August 21, 2009 Posted August 21, 2009 i wasn't thinking about it earlier, but what's the difference in using this and just using trim?pick the pline, pick the segment in the pline. Didn't know you could use trim in that way My inexperience with using AutoCAD strikes again... :wink: Quote
alanjt Posted August 21, 2009 Posted August 21, 2009 Didn't know you could use trim in that way My inexperience with using AutoCAD strikes again... :wink: i don't know why i didn't think about it earlier. as soon as i saw it posted at theswamp i realized it. since it was a request here, i thought i'd post the info. Quote
gile Posted August 22, 2009 Posted August 22, 2009 Hi, Just for fun. A little more concise using entmod (works with opened polylines too). (defun c:PlOpen (/ pl pt pa l1 l2 l3 cl) (vl-load-com) (if (and (setq pl (entsel "\nSelect the pline segment: ")) (setq pt (trans (osnap (cadr pl) "_nea") 1 0)) (setq pl (car pl)) (setq el (entget pl)) (= "LWPOLYLINE" (cdr (assoc 0 el))) ) (progn (foreach p el (if (member (car p) '(10 40 41 42)) (setq l2 (cons p l2)) (setq l1 (cons p l1)) ) ) (setq l2 (reverse l2) cl (assoc 70 el) ) (repeat (* 4 (1+ (fix (vlax-curve-getParamAtPoint pl pt)))) (setq l2 (append (cdr l2) (list (car l2)))) ) (entmod (append (subst (cons 70 (Boole 2 (cdr cl) 1)) cl (reverse l1)) l2) ) ) ) (princ) ) Quote
Lee Mac Posted August 23, 2009 Posted August 23, 2009 Hey Gile! Nice to see you in these parts - welcome to CADTutor I saw a similar method by ElpanovEvgeniy over at theSwamp - clever stuff :wink: Quote
RenManZ Posted November 7, 2009 Posted November 7, 2009 how would you change this routine to add a arc instead of removing a segment using (vla-setbulge (vlax-ename->vla-object (car (entsel))) 0 1) Quote
gile Posted November 7, 2009 Posted November 7, 2009 RenManZ (setq pl (entsel) pt (trans (osnap (cadr pl) "_nea") 1 0) pl (car pl) pa (fix (vlax-curve-getParamAtPoint pl pt)) ) (vla-setbulge (vlax-ename->vla-object pl) pa 1.0) But here's a complete routine I wrote somt times ago ;; CRUV (gile) -Gilles Chanteau- ;; Transforms a straight polyline segment into a curve one (defun c:curv (/ *error* pl pt no scu pa p1 p2 bu mid cor loop gr pm fl str ce di) (vl-load-com) (or *acdoc* (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object))) ) (defun *error* (msg) (or (= msg "Function cancelled") (princ (strcat "Error: " msg)) ) (vla-SetBulge pl pa bu) (and scu (vl-cmdf "_.ucs" "_restore" "scuinit") (vl-cmdf "_.ucs" "_delete" "scuinit") ) (grtext) (redraw) (vla-EndUndoMark *acdoc*) ) (if (and (setq pl (entsel)) (setq pt (trans (osnap (cadr pl) "_nea") 1 0)) (setq no (cdr (assoc 210 (entget (car pl))))) (setq pl (vlax-ename->vla-object (car pl))) (= (vla-get-ObjectName pl) "AcDbPolyline") ) (progn (vla-StartUndoMark *acdoc*) (if (not (and (equal '(0 0 1) (trans '(0 0 1) no 1 T) 1e-9 ) (equal 0.0 (vla-get-elevation pl) 1e-9) ) ) (and (vl-cmdf "_.ucs" "_save" "scuinit") (setq scu T) (vl-cmdf "_.ucs" "_object" (vlax-vla-object->ename pl)) ) ) (setq pa (fix (vlax-curve-getParamAtPoint pl pt)) p1 (trans (vlax-curve-getPointatParam pl pa) 0 no) p2 (trans (vlax-curve-getPointatParam pl (1+ pa)) 0 no) bu (vla-GetBulge pl pa) mid (mapcar '(lambda (x1 x2) (/ (+ x1 x2) 2.0)) p1 p2) cor (distance mid p1) loop T ) (princ "\nSpecify the height (sagitta) or [Center/Direction]: ") (while (and (setq gr (grread T 12 0)) (/= (car gr) 3) loop) (cond ((= (car gr) 5) (redraw) (setq pm (trans (cadr gr) 1 no) fl (distance mid pm) ) (and (< (sin (- (angle p1 p2) (angle p1 pm))) -1e-14) (setq fl (- fl)) ) (vla-setBulge pl pa ((lambda (a) (/ (sin a) (cos a))) (/ (- (angle p2 pm) (angle pm p1)) 2.0) ) ) (grdraw (trans mid no 1) (trans (vlax-curve-getPointAtParam pl (+ pa 0.5)) 0 1) -1 1 ) (grtext -1 (strcat "Height = " (rtos fl))) ) ((member (cadr gr) '(13 32)) (cond ((and str (numberp (read str))) (vla-setBulge pl pa (/ (read str) cor)) (setq loop nil) ) ((and str (member (strcase str) '("C" "D"))) (setq loop nil) (cond ((= (strcase str) "C") (while (not (and (setq ce (trans (getpoint "\nSpecify le center: ") 1 no ) ) (equal (distance ce p1) (distance ce p2) 1e-9) ) ) (princ "\nThe specified point can't be the arc center" ) ) (vla-SetBulge pl pa (/ (- (distance ce p1) (distance ce mid)) (if (< (sin (- (angle p1 p2) (angle p1 ce))) -1e-14) (distance p1 mid) (- (distance p1 mid)) ) ) ) (initget "Yes No") (if (= "Yes" (getkword "\nDraw the complementary arc ? [Yes/No] <No>: " ) ) (vla-SetBulge pl pa (/ (+ (distance ce p1) (distance ce mid)) (if (< (sin (- (angle p1 p2) (angle p1 ce))) -1e-14 ) (- cor) cor ) ) ) ) ) ((= (strcase str) "D") (while (not (setq di (getpoint (trans p1 no 1) "\nSpecify the direction: " ) ) ) ) ((lambda (a) (vla-SetBulge pl pa (/ (sin a) (cos a))) ) (/ (- (angle p1 p2) (angle p1 (trans di 1 no))) 2.0) ) ) ) ) (T (princ "\nNeeds a number, a valid option or a cursor input. \nSpecify the height (sagitta) or [Center/Direction]: " ) (setq str "") ) ) ) (T (if (= (cadr gr) (or (and str (/= str "") (setq str (substr str 1 (1- (strlen str)))) (princ (chr ) (princ (chr 32)) ) (setq str nil) ) (or (and str (setq str (strcat str (chr (cadr gr))))) (setq str (chr (cadr gr))) ) ) (and str (princ (chr (cadr gr)))) ) ) ) (and scu (vl-cmdf "_.ucs" "_restore" "scuinit") (vl-cmdf "_.ucs" "_delete" "scuinit") ) (grtext) (redraw) (vla-EndUndoMark *acdoc*) ) ) (princ) ) Quote
