Lee Mac Posted August 24, 2009 Posted August 24, 2009 that's pretty slick lee, nice work. Cheers dude Had a bit of help from the Swampers Quote
AQucsaiJr Posted August 27, 2009 Author Posted August 27, 2009 Got a question for you Lee, about this LISP. After I run it, by the way it works great, I can not view any of the files in thumbnail view in the folder. It would not be a big deal, like I said the LISP works great, however I need to be able to use the thumbnail view to quick view some of my drawings. Is there something in this LISP that can be adjusted so that it saves in a way that I can see the thumbnails? Quote
Lee Mac Posted August 27, 2009 Posted August 27, 2009 I wondered if this would be an issue - This is a known problem with using ObjectDBX to iterate through drawings. Look at reply #6 in this thread: http://www.theswamp.org/index.php?topic=7335.0 Quote
AQucsaiJr Posted August 27, 2009 Author Posted August 27, 2009 Sounds like it may fix the issue... I will give it a try when I get a few minutes to spare... Thanks Lee. Quote
Lee Mac Posted August 27, 2009 Posted August 27, 2009 Sounds like it may fix the issue... I will give it a try when I get a few minutes to spare... Thanks Lee. Yeah, its a shame that the C++/Arx cannot be incorporated into the ObjectDBX to prevent the issue, a shame that you have to save it separately. EDIT: forgot to mention, you will have to edit my original routine to call the Thumbnailer, as stated in the ReadMe.txt file. Quote
