muck Posted August 25, 2009 Posted August 25, 2009 When I type text into autocad i get "Unable to find Main Directory could not start speller" I think I might be missing a support folder in my support folder but I don't know which one. Any suggestions? Thank you, Quote
chelsea1307 Posted August 26, 2009 Posted August 26, 2009 looks like your missing your dictionary. check your files, under text editor, dictionary and font file names, check your main dictionary- is anything there or does it say not found? Did you recently install 2010? If you did its possible that you had a bad install and the dictionary wasnt installed, try a repair and see if that helps If you've had it installed for a while and it recently stopped working you should check to see if it got moved or possibly corrupted. Quote
