flowerrobot Posted August 26, 2009 Posted August 26, 2009 Howdy all Just finished a block in a project im making As as you all know, Osnap dosnt work with grread, And since lee and another showed me of 'osnap' command And i wanted both a vectors & osnap i developed this Please criticise. And if you can Do a better job with the osnap icons please do, As i know mine arnt perfect. Still need to add, an option to turn of osnap with shortcut keys "F3" and other F keys And the cross after going close point, Dosnt work when screen ratio is above 1. Included is a testSample in the header Please keep the header OsmodeV0.1.lsp Quote
Freerefill Posted August 26, 2009 Posted August 26, 2009 That's actually kind of cool, Flower! CommanderBill and I have done similar things, though we haven't pulled them all together, nor did I ever think to keep the blips on! Very clever. I'd like to say, though, there are a LOT of things you can do with that. You realize, you can create a whole slew of snap options that aren't otherwise available? CommandantBill and I made one which returned the center of a polyline, which was really cool. You could probably calculate the centroid as well. The sky's the limit! I'd love to see what you end up with when you're done, it seems like one part of a larger project. :3 Quote
flowerrobot Posted August 27, 2009 Author Posted August 27, 2009 Thanks for that Your right, I never thought of that, My goal was just to imitate it, But like you say, You can incorpriate many things quite easily. Only issue is thinking of what you could do really... Flower Quote
MSasu Posted August 28, 2009 Posted August 28, 2009 That’s a really great work! One suggestion, if you don’t mind: isn't better to match the list with recognized modes with the current value of OSMODE variable instead use a built-in one? I mean that even if I disable the Endpoint it is still recognized by your tool. Regards, Quote
MSasu Posted August 28, 2009 Posted August 28, 2009 And another comment, if you exit the test function with , the last marked point and blips are retained on screen; seems that a final redraw of those may be a good idea. Regards, Quote
flowerrobot Posted August 30, 2009 Author Posted August 30, 2009 I mean that even if I disable the Endpoint it is still recognized by your tool.Regards, If you have endpoint turned off at the start of it, it should stay off, but Because i need to read into all shortcuts key so that it can toggle the this, eg F3 will turn of osnap. But need a bit of time for that. Is this what you ment? if you exit the test function with , the last marked point and blips are retained on screen; seems that a final redraw of those may be a good idea. I belive i do, In my error program. So if is done in my command it should remove them. However if is pressed some where in the "While" then it wont, this is to accomidate, the user using 'grvec', well in theory any way Thanks for the comments, will do what i can when i have a bit of time thanks flower Quote
