selection of lines - display
When i select a line it used to change appearance so i knew which line i had selected (i think!) it no longer does this. I have chexked in 'options' and cannot find anywahere to change settings to rectify this problem, anyone able to help?
Eddy
Set System Variable SELECTIONPREVIEW to a value of 1, 2 or 3.
Sorry, how do i do that?? Thanks, i have managed! i used the 'highlight; command found in 'F1' help.
  • 2 months later...
type SELECTIONPREVIEW at the commandline, and press return.
at this point press the F1 key (this opens up the autocad helpfile), this will help you to determine what value to set it to
