rjracad Posted August 26, 2009 Posted August 26, 2009 I want to be able to specify the arc length of any given arc without having to use trigonometry to work out the arc angle. In the properties dialogue box the arc length is visible but greyed out & therefore cannot be changed. Does anyone have any ideas?. Quote
Tiger Posted August 26, 2009 Posted August 26, 2009 go Draw > Arc and you find all kinds of different ways to draw arcs. Quote
rkent Posted August 26, 2009 Posted August 26, 2009 I want to be able to specify the arc length of any given arc without having to use trigonometry to work out the arc angle. In the properties dialogue box the arc length is visible but greyed out & therefore cannot be changed. Does anyone have any ideas?. You will have to draw the arc to the correct radius, any length, then use Lengthen command to set length. Quote
rjracad Posted August 27, 2009 Author Posted August 27, 2009 Thanks rkent that's cracked it. I wasn't aware of lengthen command. Cheers. Quote
