Hi there,
I've been looking here and there to find a solution to my problem, found lots of things but none worked for me !
here is my problem :
I want to have some parts CNC machined, the guy wants DXF file. The thing is I'm used to work with Catia (all parametric design) so I modeled my parts in 3D with Catia, them made a 2D and converted this 2D into a DXF file. The pieces are templates to cut ski parts so it's basically the top view of a ski, meaning lots of tangent curves.
I know the 2D in Catia are not perfect (some approximations when going from 3D to 2D I guess) so my profiles are not closed or sometimes lines are overlapping (only visible when zoomed at maximium)
Anyway when I have my DXF I tweak it a bit, moving points here and there to have a continuous contour. The thing is my contours are never closed, even if visually I can see no gap at all, and that gives trouble to the CAM software at the CNC shop.
On my end, to check for closed contours I try to apply hatching to the contour by picking a point inside, it always return the "open contour" error.
The problem is I can't see where the contour is open.
Is there a way for AutoCAD to show that to me so I can fix it ? (I use AutoCAD 2006, and I'm also giving a try to 2010 as I like the parametric design feature... still have to get used to it though..)
Is there a command to close a contour or create a line linking the ends of 2 curves ? (even if visually they're already linked)
Any help would be very appreciated, I've been trying to fix that for 2 days and start to be out of ressources...
I can provide the faulty DXF file if some wants to have a look.
Thanks a lot !
Ben
(sorry for my english it's not my first language..)
Closing contours can be labor intensive, one approach I've taken is select an item using grips, zoom in tight to the gripped endpoints and then stretch to the nearby endpoint. A better approach may be to search for a lisp file that can "weed" the linework joining endpoints based on a fuzz factor. Also examine the linework to see if you are dealing with linework of varying Z values.
If these are not polylines you can attempt to convert one of the objects into a polyline then join the other members. You will receive feedback as to how many objects were added to the polyline - if the number of items is fewer than what you've selected you can visually see which objects were excluded by selecting the newly created polyline and observing the non-highlighted segments. You may need to perform this sequence several times, sometimes exploding the polyline and repeating.
hum interesting, I didn't even suspect having lines on different z axis... I'll check that as soon as i'm back home !
Thanks for all the other inputs, I already tried moving the grips, it worked visually but it's not fixing the problem...
I'll investigate a bit more on polylines but my lines are arcs, I'm afraid I'll end up with lots of straight lines whic approximate my curve...
Thanks !
Polylines can consist of arcs, you should be ok there.
