Hey i need to join the surfaces as one so i can export it all as ASIC to Gambit. Any ideas?
Thank You very much
DRAW1.dwg
I don't do much with 3d, but won't UNION do what you want?
Glen
i tired that but it seems that those are surfaces and i need 3d solids to use UNION, i've been told to use thickness and create solids and then use union, it works but its not what i want, i need to create a full solid not one with thickness!
Thanks Glen Smith
I don't know why you could not use Union. It worked for me.
KC
Hello Kencaz Thanks for the answer
When i use Union I select both surfaces the cylinder and the cone and it says "At least 2 solids or coplanar regions must be selected" So it doesnt work! Or what am i doing wrong?
Thanks
It seems like a version problem. I am able to union the surfaces with 2010, most likely because of the new mesh modeling capabilities.
I did pull, up your file in 2008 and had the same issue your describing.
I was able to use "Thicken" to add .01 to the surface and it automatically created a 3DSOLID that I was able to union.
I have to say that this is probably the easiest way and it is still a true solid.
KC
ill try upgrading to 2010.
Thanks KC
i dont know that there is a way to sew or stitch these together in pre 2010acad but you can easily draw that as one piece as a surface. If you just draw your 3 circles and loft between them, then subtract your cut outs.
