measuring length of lines automatically
Hi All,
I wanna measure automatically the total length of lines,circles,etc. which are on the model. Is there a command or script for this??? Thanks
To be clear what I meant is the periphery of a circle,thanks....
have you had a look at these
(sorry broken link)
If none of these suit , just give us a shout..:)
periphery of a circle....circumference
here's a lisp that i did not create
TLEN.LSP - Total LENgth of selected objects
(c) 1998 Tee Square Graphics
(defun C:TLEN (/ ss tl n ent itm obj l)
 (setq ss (ssget)
       tl 0
       n (1- (sslength ss)))
 (while (>= n 0)
   (setq ent (entget (setq itm (ssname ss n)))
         obj (cdr (assoc 0 ent))
         l (cond
             ((= obj "LINE")
               (distance (cdr (assoc 10 ent))(cdr (assoc 11 ent))))
             ((= obj "ARC")
               (* (cdr (assoc 40 ent))
                  (if (minusp (setq l (- (cdr (assoc 51 ent))
                                         (cdr (assoc 50 ent)))))
                    (+ pi pi l) l)))
             ((or (= obj "CIRCLE")(= obj "SPLINE")(= obj "POLYLINE")
                  (= obj "LWPOLYLINE")(= obj "ELLIPSE"))
               (command "_.area" "_o" itm)
               (getvar "perimeter"))
             (T 0))
         tl (+ tl l)
         n (1- n)))
 (alert (strcat "Total length of selected objects is " (rtos tl)))
PSPort- your link is broken...
Chris, TLEN is the answer I would have suggested to your first post, but your second post just asks about the circumference? Then you just need to highlight the circle and look in PROPERTIES.
  • 5 months later...
Dear all this is my first post on the forum.
Little about me; I am good with excel and VBA, but very much new to Lisp. I have with me Tlen and LA lisp commands. Both are working very well.
Can any body help me to join both of these. By this I may be able to find the length of a closed body as well as the enclosed area at the same time. It should be written in the region itself.
