AutoCAD 2008 opening issue
Have been using AutoCAD2008 for a while now and recently installed a trial version of 2010 on my vista laptop. In short, 2010 would not open, kept bringing up errors etc, so I uninstalled it.
Now when opening drawings in 2008, each drawing starts it's own instance of AutoCAD, so the Ctl+Tab shortcut to scroll through the drawings no longer functions.
I presume there must be a registry setting (couldn't find any options in AutoCAD) that has been changed.
Any help appreciated.
Dave
Thanks for the reply. After typing SDI into the command line (Single Document Interface) as mentioned in your reply link, the setting was 0 (default). Have downloaded the service pack, will keep you posted on progress.
Once again, thanks for the promt and exact reply.
Dave
Well, downloaded the service pack and it wouldn't install as a message came up saying it could not find the product!!
OK. Profile says 2005. Thread says 2008. We are talking 2008 right?
Forgot I even had a profile with that info :?
Yep, refering to A2008, link is for 2008, download service pack is for 2008, but wouldn't open??
Maybe you did not completely uninstall 2010 and that is the software the service pack is referring to.
Yeah, 2010 did infect the PC and left bits everywhere, even using the programs unistall I had to manually delete bits from all over the place. Heaven knows whats left in the registry
BTW, didn't you create a Restore point before installing AutoCAD 2010?
