Shibuboss Posted August 31, 2009 Posted August 31, 2009 Hello Everybody, I have a problem with using CTRL+C for copy and CTRL+V for paste,copy one object to another drawing.it's working but taking too much time.any settings related with CUI.please advise.thanks in advance. Regards_______ Quote
Dipali Posted August 31, 2009 Posted August 31, 2009 check if your drawing is not too far away from 0,0,0 in that case, instead of copy try using copy with base point. it may speed up the process. BTW I LIKE YOUR SIGNATURE Quote
Shibuboss Posted August 31, 2009 Author Posted August 31, 2009 Dipali thanks for your replay, While the time of copying file i used copy with base point command still have problem. If i am using CTRL+C for copying object; not that much late,but when i am using " CTRL+V " for paste having too much time and the system sometimes hang on.please advise. Regards_______ Quote
ReMark Posted August 31, 2009 Posted August 31, 2009 From AutoDesk: To resolve this issue, you can remove the annotation scales: On the command line, enter -SCALELISTEDIT Enter R for Reset. Enter Y to reset scale list to the default values. Enter E to exit. Quote
Tankman Posted August 31, 2009 Posted August 31, 2009 Excellent replies above! Thanks forum members. I might raise a couple of more questions, "What processor are you using? How much RAM do you have installed?" Just curious. Is it possible your PC is starving for memory? Quote
Shibuboss Posted September 1, 2009 Author Posted September 1, 2009 Thanks a lot Remark Sir. Really it work amazing.thanks a lot. Regards________ Quote
Shibuboss Posted September 1, 2009 Author Posted September 1, 2009 original quote Excellent replies above! Thanks forum members. I might raise a couple of more questions, "What processor are you using? How much RAM do you have installed?" Just curious. Is it possible your PC is starving for memory? Thanks for your replay Tankman. See the details:- Computer: Inter® Core ( TM )2 Duo CPU E4500 @ 2.20GHz 2.21 Ghz, 1.99 GB of RAM Regards________ Quote
ReMark Posted September 1, 2009 Posted September 1, 2009 I'm glad to hear that the solution suggested by AutoDesk worked for you. The AutoDesk website is a good source of information despite the fact it is sometimes difficult to find it. I suggest you add it to your "Favorites" list or bookmark it in some fashion. Quote
Shibuboss Posted September 1, 2009 Author Posted September 1, 2009 Thanks for your replay and advise Sir. Already i added AutoDesk site to my favorite.some times it's hard to find the things i am searching for.thank you. Regards_______ Quote
