Dynamic block Scale
I am creating a dynamic block symbol for a Manhole. I was to set the block up to have an attribute so it can be set to "MH" or a number as required. I want the block to be scaleable to 3 scales. We will only have services on drawings @ 250, 500, and 1000.
I have tried to link the list in the linear paramter to the lookup but am having trouble.
Can anyone help?????
Could you just draw the block at paperspace size and make the block annotative?
Why don't you make 3 visibility states?
I was going to do that but then I need to include the MH text as an attribute and allow it to be edited. To create 3 visibility state I would need 3 attributes.
This is the block. I tried to link a linear parameter with the lookup routine but I don't know if I did it right.
mh.dwg
