How to i check for characters in the 'dwgname' variable
I’m trying to create a lisp test expression for my if then statement…& I’m stuck. Basically, all I need is:
If the dwgname contains this word (MyPlan), then do this …
The dwgname is typically formatted ‘xxxx~MyPlanxxxx.dwg’. The xxxx represents 4 or more letters/numbers. I tried using wildcards, but doesn’t work.
Thanks in advance!
You could use the wcmatch function:
Either:
(wcmatch (getvar "DWGNAME") "*MyPlan*")
Or
(wcmatch (getvar "DWGNAME") "????~MyPlan*")
Lee
Awesome!...worked perfectly, thanks again!
