RevolverSly Posted September 1, 2009 Posted September 1, 2009 Hello. I have a trouble in Autocad 2007, when i open any dwg file, a LISP command started, display a annoying warning window ("this is a good code"), an LISP text file is created in the same directory where the dwg file are, and finally don't let me explode anything. I think somewhere a got a file with that code, but now i don't know how to get rid of it, please any suggestion? Thanks in advance. Goodbye. Quote
Lee Mac Posted September 1, 2009 Posted September 1, 2009 Investigate what LISPs you have in your Start-up Suite or ACADDOC.lsp and find out which one is causing the message to appear. The LISP has most probably redefined your explode command. Quote
RevolverSly Posted September 9, 2009 Author Posted September 9, 2009 Hello. Well, before anything, thanks for the very quick reply. Actually, the trouble was in a diferent machine that I use day by day, so I fix the trouble some days later. As mentioned before, the issue was fixed, just open the acad.lsp file that was created every time I open a dwg, find the word "explode", erase 3 lines (the lsp script was undefined xr and bind options also, but don't even noticed, by the way), delete the line of the bloody warning message ("this is a good code") and next time I open acad they ask me about multiple enviroment, so just tell it use the default enviroment for every drawing and don't ask me again, and that's all. Guess so. Goodbye Quote
Lee Mac Posted September 9, 2009 Posted September 9, 2009 Glad you got it sorted - at least you know what to look out for next time Quote
