I am using AutoCAD 2008. My properties command has stopped working. I double left click - nothing! Right click and click properties - nothing! I click properties on the toolbar - nothing! Can you help?
Has it been dragged off screen?
Is there any response in the command line?
It says properties in the command line. How can I see if it has been dragged off screen?
try increasing the screen resolution.
If it is not this, which realistically it probably isn't, then have you run a virus scan or registry clean recently?
I would suggest you try to repair the installation. Go to the control panel, the add/remove (or something similar) select AutoCAD 2008, click change and then Repair. This should correct it.
If it does not, then get back to us.
  • 2 years later...
hi,
I AM AHVING SAME PROBLEM,WHICH IS I COULDN'T FIX IT. CAN YOU HELP ME OUT FOR THIS
THANKS
RRAJ
Try CTRL+1 followed by ALT+TAB see if you can have it's menu popped up somewhere on the screeen.
  • 1 year later...
Both my "Properties" and Matchprop" commands are giving me "unknown command" errors. I get this no matter if I try typing "MA", right click to properties, or by tool bar buttons.
