luistyle619 Posted September 1, 2009 Posted September 1, 2009 I have a batchplot program that was created specific for our application it works great. Program allows to Hide Wipeout at the click of a button (code) while its batch plotting into PDF. Problem is that it hides the 'Wipeout' layer for the drawing that its plotting but wont hide the wipeouts that are being xref'd in. in other words it hides layer - 'wipeout' but does not hide layer - 'xbase1Iwipeout' It only looks for the wipeout layer of the current drawing and does not include the xrefs... I think this is where I need to modify but I have also attached the whole module in txt format. runit: Dim layer As AcadLayer For Each layer In ThisDrawing.Layers If UCase(layer.name) = "WIPEOUT" Then ThisDrawing.ActiveLayer.Lock = False ThisDrawing.Layers("WIPEOUT").Lock = False ThisDrawing.Layers("WIPEOUT").Freeze = True ThisDrawing.Layers("WIPEOUT").LayerOn = False End If Exit For Next any help would be great!!!! Thanks! hidewipeoutcodemodule.txt Quote
