Hi all!
I am trying to use convtosurface command to convert bunch of 3dfaces to surfaces. I don't know why (obviously:D), but not all of 3dfaces are converted after running the command. I used splframe=1 to make all faces visible but no change.
I am getting the message:
Specify opposite corner: 74 found
Select objects:
18 objects cannot be converted.
I have no idea what to do next and I really need this to work.
Any help would be great!!!!
Thanks,
Peja
Sounds like you have some bad 3Dfaces.
Maybe some of them are overlapping?
I think you're just going to have to do some detective work and figure out where the 18 problem areas are, and fix them.
  • 13 years later...
Hello,
I have the same problem for more than 300 faces on the model of a concert hall.
I found one of the faces that can't be converted, I try deleting it to redraw it. I verify, and there is no overlapping but nothing worked...
I attach the part of the drawing where 2 faces can't be converted using convtosurface, and I'm using AutoCAD2022.
I will be really thankful if you can find a solution.
https://drive.google.com/file/d/1Gt167K_QhKMKVZ-Ope1bpFgHHJGzi0DD/view?usp=sharing
I don't know what's wrong with that one 3D face that won't convert, so I simply created a new polyline boundary, deleted the bad face and then ran the CONVTOSURFACE command and everything converted fine.
Drawing2-Converted.dwg
