PanHasan Posted September 2, 2009 Posted September 2, 2009 Hi i got a question how could i create a array that will contain start and end points of a lines tab(0)[pt1 pt2] first line tab(1)[pt1 pt2] second line should i use something like this it works but the points are all together so its not perfect Dim Tab() As Point3d Quote
SEANT Posted September 2, 2009 Posted September 2, 2009 There are several methods to store the coordinates associated with points, and the best choice would probably depend on the downstream requirements of the data. Arrays are a valid option, and may even be the most efficient from a computer processing perspective. If the type and quantity of Points is unknown, arrays are a bit of a handful for the coder, however. The Autodesk.AutoCAD.Geometry.Point3dCollection is very easy to use - as points can be added and subtracted at will. With regard to collections (and their general ease of use), the System.Collections.Generic Namespace offers several other ways of storing points (or any data for that matter) and have the added benefit of making code more universal, i.e., not limited to just AutoCAD routines. Quote
PanHasan Posted September 3, 2009 Author Posted September 3, 2009 I think that is no need to create a new thread so i'll ask here have you got any idea why the ray in the function is not visible in the drawing if i use that code without function it works OK <CommandMethod("src")> _ Public Sub src() Dim lCmd As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim acBaza As Database = lCmd.Document.Database Dim trn As Transaction = acBaza.TransactionManager.StartTransaction Dim lnL1 As Line = New Line() Dim usrPtOp As PromptPointOptions = New PromptPointOptions("Wskarz srodek pomieszczenia :") Dim usrPt As PromptPointResult = lCmd.GetPoint(usrPtOp) Dim prevPt As Point3d = usrPt.Value Dim nextPt As Point3d = usrPt.Value If usrPt.Status = PromptStatus.OK Then Dim usrPtXmod As Point3d = New Point3d(usrPt.Value.X + 1, usrPt.Value.Y, usrPt.Value.Z) Dim promienSledzacy As Ray = New Ray() promienSledzacy.BasePoint = usrPt.Value promienSledzacy.SecondPoint = usrPtXmod 'FILTRACJA LINII Dim typeValue() As TypedValue = {New TypedValue(0, "line")} Dim selFilter As SelectionFilter = New SelectionFilter(typeValue) Dim selResult As PromptSelectionResult = lCmd.SelectAll(selFilter) Dim ssLinie As SelectionSet = selResult.Value Dim tabID() As ObjectId = ssLinie.GetObjectIds Dim lnNajblizsza As Line = Nothing 'TRANSAKCJA przecieciaPromienia(promienSledzacy, tabID, prevPt, nextPt, lnNajblizsza) 'Sprawdzenie ktury punkt jest nizej Dim START As Point3d Dim FIN As Point3d If lnNajblizsza.StartPoint.Y > lnNajblizsza.EndPoint.Y Then START = lnNajblizsza.EndPoint Else START = lnNajblizsza.StartPoint End If End If End Sub Public Sub przecieciaPromienia(ByRef promienSledzacy As Ray, ByRef tabID() As ObjectId, ByRef prevPt As Point3d, ByRef nextPt As Point3d, ByRef lnNajblizsza As Line) Dim lCmd As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim acBaza As Database = lCmd.Document.Database Dim trn As Transaction = acBaza.TransactionManager.StartTransaction Try Dim btr As BlockTableRecord = trn.GetObject(acBaza.CurrentSpaceId, OpenMode.ForWrite) Dim objID As ObjectId Dim ra3d As Ray3d = New Ray3d(promienSledzacy.StartPoint, promienSledzacy.SecondPoint) Dim odl As Single = 0.0 Dim odlTmp As Single = 0.0 For Each objID In tabID Dim ln As Line = CType(trn.GetObject(objID, OpenMode.ForRead), Line) Dim ls As LineSegment3d = New LineSegment3d(ln.StartPoint, ln.EndPoint) Dim ptArray() As Point3d = ls.IntersectWith(ra3d) If ptArray Is Nothing Then Continue For Dim ptkPrzeciecia As Point3dCollection = New Point3dCollection(ptArray) 'SZUKANIE PIERWSZEJ NAJBLIZSZEJ LINII ' odl=sqrt ((x1-x2)*(x1-x2) + (y1-y2)*(y1-y2)) odlTmp = Math.Sqrt((prevPt.X - ptkPrzeciecia.Item(0).X) * (prevPt.X - ptkPrzeciecia.Item(0).X) + (prevPt.Y - ptkPrzeciecia.Item(0).Y) * (prevPt.Y - ptkPrzeciecia.Item(0).Y)) If odl = 0.0 Then odl = odlTmp nextPt = ptkPrzeciecia.Item(0) lnNajblizsza = ln ElseIf odl >= odlTmp Then nextPt = ptkPrzeciecia.Item(0) lnNajblizsza = ln End If Next lnNajblizsza.Highlight() promienSledzacy.SetDatabaseDefaults() btr.AppendEntity(promienSledzacy) trn.AddNewlyCreatedDBObject(promienSledzacy, True) trn.Commit() Catch ex As Exception Finally trn.Dispose() End Try End Sub Quote
SEANT Posted September 3, 2009 Posted September 3, 2009 I wouldn’t exactly say it is a definite but passing open database object references between sub/functions may not be the best practice. I modified the structure to illustrate an alternative. Note: Autodesk.AutoCAD.Geometry objects are not database residents I think the reason that the Ray was not showing was because the top level transaction had not been committed. Again, I modified the routine to illustrate that point. <CommandMethod("src")> _ Public Sub src() Dim lCmd As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim acBaza As Database = lCmd.Document.Database Using trn As Transaction = acBaza.TransactionManager.StartTransaction Dim lnL1 As Line = New Line() Dim usrPtOp As PromptPointOptions = New PromptPointOptions("Wskarz srodek pomieszczenia :") Dim usrPt As PromptPointResult = lCmd.GetPoint(usrPtOp) Dim prevPt As Point3d = usrPt.Value Dim nextPt As Point3d = usrPt.Value If usrPt.Status = PromptStatus.OK Then Dim usrPtXmod As Point3d = New Point3d(usrPt.Value.X + 1, usrPt.Value.Y, usrPt.Value.Z) Dim ls3d As LineSegment3d = New LineSegment3d(usrPt.Value, usrPtXmod) 'FILTRACJA LINII Dim typeValue() As TypedValue = {New TypedValue(0, "line")} Dim selFilter As SelectionFilter = New SelectionFilter(typeValue) Dim selResult As PromptSelectionResult = lCmd.SelectAll(selFilter) Dim ssLinie As SelectionSet = selResult.Value Dim tabID() As ObjectId = ssLinie.GetObjectIds Dim oid As ObjectId 'TRANSAKCJA oid = przecieciaPromienia(ls3d, tabID, prevPt, nextPt) Dim lnNajblizsza As Line = CType(trn.GetObject(oid, OpenMode.ForRead), Line) 'Sprawdzenie ktury punkt jest nizej Dim START As Point3d 'Dim FIN As Point3d If lnNajblizsza.StartPoint.Y > lnNajblizsza.EndPoint.Y Then START = lnNajblizsza.EndPoint Else START = lnNajblizsza.StartPoint End If End If trn.Commit() End Using End Sub Public Function przecieciaPromienia(ByRef ls3d As LineSegment3d, ByRef tabID() As ObjectId, ByRef prevPt As Point3d, ByRef nextPt As Point3d) As ObjectId Dim lCmd As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim acBaza As Database = Application.DocumentManager.MdiActiveDocument.Database Dim lnNajblizsza As Line = Nothing Using trn As Transaction = acBaza.TransactionManager.StartTransaction Try Dim btr As BlockTableRecord = CType(trn.GetObject(acBaza.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord) Dim objID As ObjectId Dim ra3d As Ray3d = New Ray3d(ls3d.StartPoint, ls3d.EndPoint) Dim odl As Single = 0.0 Dim odlTmp As Single = 0.0 For Each objID In tabID Dim ln As Line = CType(trn.GetObject(objID, OpenMode.ForRead), Line) Dim ls As LineSegment3d = New LineSegment3d(ln.StartPoint, ln.EndPoint) Dim ptArray() As Point3d = ls.IntersectWith(ra3d) If ptArray Is Nothing Then Continue For Dim ptkPrzeciecia As Point3dCollection = New Point3dCollection(ptArray) 'SZUKANIE PIERWSZEJ NAJBLIZSZEJ LINII ' odl=sqrt ((x1-x2)*(x1-x2) + (y1-y2)*(y1-y2)) odlTmp = Math.Sqrt((prevPt.X - ptkPrzeciecia.Item(0).X) * (prevPt.X - ptkPrzeciecia.Item(0).X) + (prevPt.Y - ptkPrzeciecia.Item(0).Y) * (prevPt.Y - ptkPrzeciecia.Item(0).Y)) If odl = 0.0 Then odl = odlTmp nextPt = ptkPrzeciecia.Item(0) ElseIf odl >= odlTmp Then nextPt = ptkPrzeciecia.Item(0) End If lnNajblizsza = ln Next lnNajblizsza.Highlight() Dim promienSledzacy As Ray = New Ray() promienSledzacy.BasePoint = ls3d.StartPoint promienSledzacy.SecondPoint = ls3d.EndPoint promienSledzacy.SetDatabaseDefaults() btr.AppendEntity(promienSledzacy) trn.AddNewlyCreatedDBObject(promienSledzacy, True) trn.Commit() Catch ex As Exception End Try Return lnNajblizsza.ObjectId End Using End Function Quote
PanHasan Posted September 3, 2009 Author Posted September 3, 2009 Thanks for the advice and the solution Quote
