I made a VBA program to insert blocks. The user has to select the insertion point and rotate the block. What I would actually like to do is to insert the blocks aligned to a selected line, just as the alignment parameter in dynamic blocks would do...
Why not just add an alignment parameter to your blocks ?
Because the program creates the blocks first with user defined properties. If I would have to create the blocks myself it would take me ages. It's hundreds of them.
If the active UCS is always parallel to the WCS then it would be a matter setting Insert.Rotation equal to the angle returned by Thisdrawing.Utility. AngleFromXAxis(Line.StartPoint, Line.EndPoint)
It is a bit more complicated when working with a full 3D environment. In that case some coordinate transformations would be required. See (towards the bottom):
http://discussion.autodesk.com/forums/thread.jspa?messageID=5825469
