Problems with loading applications
I've been having alot of issues with Civil 3d 2008
Ok first problem is with Vault. Dont really need it here at work since we only have 4 users of Civil 3d. Is there a way to "turn off" Vault w/o removing it from programs. I ask only because our IT are the only ones that can install and remove programs from our computers, and our IT department is slow.
I would go ahead and use this program if i only knew the username and password, server, and database. I've tried using the default login but doesnt work, nor does adminstrator.
problem 2
If i had the authority to do a clean install of civil 3d i would but i dont.
The default profile "unnamed Profile" has issues
The applications in the civil folder arent loaded when i start up civil 3d
So i go to "appload" and load them from there and here is what i get
Command: appload
C:\Program Files\AutoCAD Civil 3D 2008\Civil\AeccUiModel.arx cannot find a dll
or other file that it needs.
AcRxDynamicLinker failed to load 'C:\Program Files\AutoCAD Civil 3D
2008\Civil\AeccUiModel.arx'
C:\Program Files\AutoCAD Civil 3D 2008\acad.exeUnable to load AeccUiModel.arx
file.
Loading AECC Pipe Network UI...
Loading AECC Roadway UI...Successfully loaded 11 files.
Isn't this suppose to to load automatically?
Well the AeccUImodel.arx is the application i need to load, sounds like it has something to do with the tool space pallette. It will not load up for nothing.
My support file search path should be correct and in this order
C:\Documents and Settings\******_*****\Application Data\Autodesk\C3D 2008\enu\support
C:\Program Files\AutoCAD Civil 3d 2008\support
C:\Program Files\AutoCAD Civil 3d 2008\fonts
C:\Program Files\AutoCAD Civil 3d 2008\help
C:\Program Files\AutoCAD Civil 3d 2008\express
C:\Program Files\AutoCAD Civil 3d 2008\support\color
C:\Program Files\AutoCAD Civil 3d 2008\Civil
C:\Program Files\AutoCAD Civil 3d 2008\Getting Started Guide
C:\Program Files\Common Files\Autodesk Shared\AxUi
C:\Program Files\AutoCAD Civil 3d 2008\FDO\bin\com
C:\Program Files\Raster Design 2008 OE
If im wrong or missing anything please tell me.
had a weird issue with default profile, if i set it as current all my menus would be gone except adobe ones and vault ones and if i typed anything in the command line, civil 3d would close out.
I first discovered this problem when i went the do "menuload" Civil and went to import points and it didnt recognize the command.
Ok yet another problem
Just FYI im new to civil 3d but not new to AutoCAD, so im just trying to learn how to use this program, anyways
i got tired of trying to figure out how to fix the default profile
so i went to use the "AUTOCAD" profile because i was able to load the civil applications and bring up Toolspace.
I imported some points, created a boundary, i saved my drawing, and than went to rebuild a surface, than i get a Fatal error message and it craps out on me.
I go back to my drawing and i get a message "Fail to get CommCntrManager!"
heres what the command line says
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: CUSTOM
Customization file loaded successfully. Customization Group: IMPRESSION
Customization file loaded successfully. Customization Group: VAULT
Customization file loaded successfully. Customization Group: ACROBAT_COMMENT
Customization file loaded successfully. Customization Group: ADOBE_PDF
Customization file loaded successfully. Customization Group: EXPRESS
Customization file loaded successfully. Customization Group: CIVIL
Customization file loaded successfully. Customization Group: MAPCLASSIC
Customization file loaded successfully. Customization Group: MAP3DDRAWING
Customization file loaded successfully. Customization Group: MAP3DGEOSPATIAL
Loading AEC Base...
Loading AECC Base...
Loading AEC Base Extended...
Loading AEC Base UI...
Loading AECC Land...
Loading Modeler DLLs.
Loading AECC Survey...
Loading AECC Pipe Part...
Loading AECC Pipe Network...
Loading AECC Roadway...
Loading AECC Plan Production...
Loading AEC Project Base...
Loading AEC Schedule Data...
Loading AEC Schedule...
Opening an AutoCAD 2000 format file.
Regenerating model.
Initializing.........Done.
Initializing VBA System...
C:\Program Files\AutoCAD Civil 3D 2008\Civil\AeccUiModel.arx is an invalid ARX
file.
Unable to load customization file: C:\Documents and
Settings\amanda_slone\Application Data\Adobe\Acrobat\9.0\ACAD-6000-409\PDFIC.cui
That Customization Group name already exists.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application
or Autodesk licensed application.
Command: COMMANDLINE
Command: *Cancel*
Command: showts
There are currently no palettes to show in the Toolspace window.
Command: appload
Unable to load AeccUiSvCalculator.arx file.
Unable to load AeccConvertLdtObjectsToC3D.arx file.
Unable to load AeccEventViewer.arx file.
Unable to load AeccPublish.arx file.
Unable to load AeccUiBase.arx file.
Unable to load AeccUiDataMigration.arx file.
Unable to load AeccUiLand.arx file.
file.
file.
Unable to load AeccUiNetwork.arx file.
C:\Program Files\AutoCAD Civil 3D 2008\Civil\AeccUiRoadway.arx is an invalid
ARX file.
2008\Civil\AeccUiRoadway.arx'
C:\Program Files\AutoCAD Civil 3D 2008\acad.exeUnable to load AeccUiRoadway.arx
file.
Unable to load AeccUiSurvey.arx file.
AeccPublishKML.arx already loaded.
Than i went to load the civil applications
Command: appload
file.
file.
ARX file.
file.
yeah...
Well, if you are really as clamped down by IT as you say, I'm not sure what you CAN do. If your ">" is corrupted, then your best bet is to reinstall. DO NOT use the "AutoCAD" Profile and attempt to appload C3D into it - that WILL NOT work. There are settings in the "AutoCAD" Profile that are incorrect for Civil 3D, and the only way I know of to edit them is via REGEDIT (and editing the Profile via REGEDIT is not recommended, unless you really know what you're doing). And you should not need to appload any of the Civil 3D components, in any case.
The best way to use Civil 3D is to start with the ">" as it exists immediate after installation. Then create a new Profile with an actual name, such as "C3D2008", that is a copy of the "Unnamed Profile", and use that as your user profile. Now do all your customizations in this Profile, and change all the Windows shortcuts in your Start menu and on your desktop so that they load your new "C3D2008" Profile when you click on them instead of the ">". (As one final note, DO NOT use angle brackets in your Profile name - that's what prevents the ">" from being exported and reimported. I have no idea why Autodesk uses the name ">", since it creates problems, but it's been like this for many years now.)
  • 3 weeks later...
well my computer was so screwed up in the first place. it would freeze up if i initiated the plot command, options, delete things off of desktop, right click on shortcut documents, empty recycle bin, open more than 1 document, start a new email, pan and zoom on a pdf, take 3 mins to log in to my computer vs 3 seconds and have some programs that get prompted to end before i shut down like acrodist.exe, F, ctfmon.exe and some others.
had to do a system restore twice to get civil 3d working right and something was wrong with DotNet..it was corrupted.
plus had to defrag my computer
If you're having that many problems, it sounds like your best bet is a hard-drive reformat and complete reinstall of everything.
