nannabug Posted May 26, 2005 Posted May 26, 2005 I'm using AutoCAD 2002. When drawing a section, is there an easier way to draw insulation than just drawing lines and then filleting them? Thank you in advance. Quote
f700es Posted May 26, 2005 Posted May 26, 2005 I'm using AutoCAD 2002. When drawing a section, is there an easier way to draw insulation than just drawing lines and then filleting them?Thank you in advance. What, BATT insulation? If so there is a linetype style for it. F7 Quote
nannabug Posted May 26, 2005 Author Posted May 26, 2005 Thanks, f700es. Found the linetype and loaded it. Have been playing around with it some and haven't figured out how to make it fit the width of the area I wish to fill. Can do length by drawing the linetype as you advised, but not the width. Is there a way to fill an area as is done with a hatch? Quote
f700es Posted May 26, 2005 Posted May 26, 2005 Thanks, f700es. Found the linetype and loaded it. Have been playing around with it some and haven't figured out how to make it fit the width of the area I wish to fill. Can do length by drawing the linetype as you advised, but not the width. Is there a way to fill an area as is done with a hatch? PLay with the linetype scale of the line in the properties box. That should do it Quote
Cyberkid Posted July 2, 2009 Posted July 2, 2009 Hi there all CAD people - I am still looking for an ZIG ZAG lisp routine that works well. Meanwhile I think I can help some of you guys with a small lisp routine for normal well drawed isolation. Best ragards- and please look at my other messages for further information. isop.LSP isot.LSP Quote
