We are working with drawings from a vender that were done in AutoCAD 2008 and we are running AutoCAD 2005. We need to be able to edit the text created w/ multileader. Is there a way to convert the multileader to text/leader that can be used in 2005 rather then exploding it?
Please let me know......thanks in advance.......
None that I know of - time to upgrade :(
Someone here (other than me) may have some code to do that though...?
i don't have anything older than 09 installed. paste this into autocad, select one of the objects and give us the results.
(vl-load-com)
(vlax-dump-object (vlax-ename->vla-object (car (entsel))))
and
(entget (car (entsel)))
Ask your vendor to save to '05 and email the drawings to you.
Most often I save to 2000 *.dwg by customer request if I'm sending them a drawing. Trusted clients of course.
does that change them to text & leaders?
No way I can think of either.
But do know later on you get in to trouble if STYLE was selected for a different than normal text font or size.
Wm.
Having the them save down to 2005 just makes them proxy entities and by exploding the proxy entity you explode the text to dingle line text and the leader into 3 parts......nothing so far works.....
use the code i posted in post #3 and give us the results.
Command: (vl-load-com)
Command: (vlax-dump-object (vlax-ename->vla-object (car (entsel))))
Select object: ; IAcadMLeader: AutoCAD Multi-Leader Interface
; Property values:
; Application (RO) = #
; ArrowheadBlock = ""
; ArrowheadSize = 3.125
; ArrowheadType = 0
; BlockConnectionType = 0
; ContentBlockName = ""
; ContentBlockType = 6
; ContentType = 2
; Document (RO) = #
; DogLegged = -1
; DoglegLength = 1.25
; Handle (RO) = "2DA40"
; HasExtensionDictionary (RO) = 0
; Hyperlinks (RO) = #
; LandingGap = 0.75
; Layer = "TEXT"
; LeaderCount (RO) = 1
; LeaderLineColor = #
; LeaderLineType = "ByLayer"
; LeaderLineWeight = -1
; LeaderType = 1
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; Material = "ByLayer"
; ObjectID (RO) = 2129930560
; ObjectName (RO) = "AcDbMLeader"
; OwnerID (RO) = 2129698040
; PlotStyleName = "ByLayer"
; ScaleFactor = 1.0
; StyleName = "2.5 IN LTR ARCH"
; TextBackgroundFill = 0
; TextDirection = 5
; TextFrameDisplay = 0
; TextHeight = 2.5
; TextJustify = 1
; TextLeftAttachmentType = 1
; TextLineSpacingDistance = 4.16667
; TextLineSpacingFactor = 1.0
; TextLineSpacingStyle = 1
; TextRightAttachmentType = 1
; TextRotation = 0.0
; TextString = "8\" PVC 90%%D ELBOW\\P(PIVOT)"
; TextStyleName = "Standard"
; TextWidth = 0.0
; TrueColor = #
; Visible = -1
T
Command: (entget (car (entsel)))
Select object: ((-1 . ) (0 . "MULTILEADER") (330 .
) (5 . "2DA40") (100 . "AcDbEntity") (67 . 0) (410 .
"Model") (8 . "TEXT") (100 . "AcDbMLeader") (300 . "CONTEXT_DATA{") (40 . 1.0)
(10 257.765 -91.6326 0.0) (41 . 2.5) (140 . 3.125) (145 . 0.75) (174 . 1) (175
. 1) (176 . 0) (177 . 0) (290 . 1) (304 . "8\" PVC 90%%D ELBOW\\P(PIVOT)") (11
0.0 0.0 1.0) (340 . ) (12 258.515 -89.966 0.0) (13 1.0
0.0 0.0) (42 . 0.0) (43 . 0.0) (44 . 0.0) (45 . 1.0) (170 . 1) (90 .
-1073741824) (171 . 1) (172 . 5) (91 . -1073741824) (141 . 0.0) (92 . 0) (291 .
0) (292 . 0) (173 . 0) (293 . 0) (142 . 0.0) (143 . 0.0) (294 . 0) (295 . 0)
(296 . 0) (110 247.483 -75.9879 0.0) (111 1.0 0.0 0.0) (112 0.0 1.0 0.0) (297 .
0) (302 . "LEADER{") (290 . 1) (291 . 1) (10 256.515 -91.6326 0.0) (11 1.0 0.0
0.0) (90 . 0) (40 . 1.25) (304 . "LEADER_LINE{") (10 247.483 -75.9879 0.0) (91
. 0) (305 . "}") (303 . "}") (301 . "}") (340 . ) (90 .
279552) (170 . 1) (91 . -1073741824) (341 . ) (171 . -1)
(290 . 1) (291 . 1) (41 . 1.25) (42 . 3.125) (172 . 2) (343 .
7ef09c88>) (173 . 1) (95 . 1) (174 . 1) (175 . 0) (92 . -1073741824) (292 . 0)
(93 . -1056964608) (10 1.0 1.0 1.0) (43 . 0.0) (176 . 0) (293 . 0) (294 . 0)
(178 . 0) (179 . 1) (45 . 1.0))
Hope this helps......
