I found this lisp somewhere here in this forum.
Does anyone know how to translate it to VBA code?
Thanks
;; Created: Author Unknown.
;**************NEW ROTATE**********************
;;; Command Line Syntax: RT
;;; Use this routine to change the angle of the crosshairs,
;;; by clicking on an object that is at the desired angle or
;;; by entering an angle of degrees at the command line.
;;; A positive number turns the crosshairs counter-clockwise.
;;; A negative number turns the crosshairs clockwise.
(defun c:rt ( / r e p1 p2)
(graphscr)
(initget "Entity")
(setq r
(getangle "\nSnap rotation angle/<Entity>: "))
(cond
( (numberp r)
(setvar "snapang" r))
( (and (or (not r) (eq r "Entity"))
(setq e (entsel))
(setq p1 (osnap (cadr e) "qui,end"))
(setq p2 (osnap (cadr e) "qui,mid")))
(setvar "snapang" (angle p1 p2)))
(t (princ "\nInvalid selection.")))
