draw chainage on polyline
motee-z
  • Replies 48
  • woodman78
    8
  • fixo
    6
  • motee-z
    3
  • Lee Mac
    3
Posted Images
(defun answer (quest / wshl ans)
(or (vl-load-com))
(setq wshl  (vlax-get-or-create-object "WScript.Shell"))
(setq ans  (vlax-invoke-method   wshl   'Popup quest 7 "Answer This Question:" vlax-vbYesNo))
(vlax-release-object wshl)
(cond  ((= ans 6)  (setq  opt T))
           ((= ans 7)  (setq opt nil)))
            opt )
(setq opt (answer "Rotate text perpendicularly to pline?"))
Hai Oleg,
This function is new to me. I like it. And I'll keep in my lib.
Thank you.
mardi
My version:
http://lee-mac.com/popup.html
when u got the mail as just write subject as "CHAINAGE LISP"
Regard
Hari
Please provide your help in the forum, as this provides help and information for all.
"Give a man a fish and he'll eat for a day, but teach a man how to fish and he will be fed for a lifetime."
Hello Mr. Lee
I want to use their code
Why does not reflect the so?
Please help!
lg. Martin
;;-------------------------=={ Popup }==----------------------;;
;;  Displays a pop-up message box prompting the user.         ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  title - Text to be displayed in the pop-up title bar      ;;
;;  msg   - Text content of the pop-up message box            ;;
;;  flags - Integer indicating icon & button appearance       ;;
;;  Returns:  Integer indicating the button pressed to exit   ;;
(defun LM:Popup ( title msg flags / wsh res )
 (vl-catch-all-apply
   (function
     (lambda nil
       (setq wsh (vlax-create-object "WScript.Shell"))
       (setq res (vlax-invoke-method wsh 'popup msg 0 title flags))
 (if wsh (vlax-release-object wsh))
 res
( LM: Popup "Titel Text"  "This is a test message".  ( +  3  32 4096 ))
;;;;;New new new
(initget "6 7 2 ")
 (cond
 ((= kw "6")(command "spiegeln" "V" "" Pause Pause "J"))
 ((= kw "7")(command "_exit"))
 ((= kw "2")(command "_exit"))
 (t 2)
Hi Martin,
There are too many spaces in your code, and an extra "." where it shouldn't be.
This:
Should be:
(LM:Popup "Title Text" "This is a test message." (+ 3 32 4096))
I meant that it is necessary to varnish the basic program
But the subroutine is good enough and works with no problem
Yes it is now working correctly.
  • 5 months later...
can someone help me fix the last chainage to show the length of the line instead of the approx. chianage
I have modified the lisp slightly to match my colours and to use pre-fix CH
(defun div-error (msg)
(if
(vl-position
msg
'("console break"
"Function cancelled"
"quit / exit abort"
(princ "Error!")
(princ msg)
(while (> (getvar "cmdactive") 0) (command))
;;; (command "._undo" "_end")
;;; (command "._u")
(setq *error* olderror)
(defun divplus (len segm / num lst)
(setq num (fix (/ len segm)))
(setq cnt 0)
(while (<= cnt num)
(setq tmp (* cnt segm))
(setq lst (append lst (list tmp)))
(setq cnt (1+ cnt))
(setq delta (- len (last lst)))
(if (not (zerop delta))
(setq lst (append lst (list (+ (last lst) delta))))
lst
(defun divminus (len segm / lst)
(while (>= len 0.)
(setq lst (append lst (list len)))
(setq len (- len segm))
(if (not (zerop (last lst)))
(setq lst (append lst (list 0.0)))
lst
(defun alg-ang (obj pnt)
(angle '(0. 0. 0.)
(vlax-curve-getfirstderiv
obj
(vlax-curve-getparamatpoint
obj
pnt
(or (vl-load-com))
wshl
(cond ((= ans 6)
(setq opt T))
((= ans 7)
(setq opt nil))
opt
(defun make-station (bname / acsp adoc atprom attag at_obj
blk_obj hgt lay line_obj sfar )
(vl-load-com)
(setq adoc (vla-get-activedocument
(vlax-get-acad-object)
(if (and
(= (getvar "tilemode") 0)
(= (getvar "cvport") 1)
(setq acsp (vla-get-paperspace adoc))
(setq acsp (vla-get-modelspace adoc))
(vla-startundomark adoc)
(if (not (tblsearch "block" bname))
(setq attag "NUMBER" ;(strcase (getstring "\nAttribute tag : \n"))
atprom "NUMBER" ;(strcase (getstring T "\nAttribute prompt : \n"))
hgt 1.0 ;(getreal "\nAttribute text height : \n")
(setq lay (getvar "clayer"))
(setvar "clayer" "0")
(setvar "attreq" 0)
(setq line_obj (vlax-invoke acsp 'Addline '(0. 0. 0.) (list 0. (* hgt 8.) 0.)))
(vla-put-color line_obj acwhite)
(setq blk_obj (vla-add (vla-get-blocks adoc) (vlax-3d-point '(0. 0. 0.)) bname)
sfar (vlax-safearray-fill
(vlax-make-safearray vlax-vbObject '(0 . 0))
(list line_obj)
(vla-copyobjects adoc sfar blk_obj)
;;; RetVal = object.AddAttribute(Height, Mode, Prompt, InsertionPoint, Tag, Value)
(setq at_obj (vla-addattribute blk_obj
hgt
acattributemodeverify
atprom
(vlax-3d-point '(-0.5 1. 0.))
attag
"0+00")
;;; (vla-put-alignment at_obj acAlignmentBottomCenter)
;;; (vla-put-textalignmentpoint
;;; at_obj
;;; (vlax-3d-point '(0. 1. 0.))
(vla-put-rotation at_obj (/ pi 2))
(vlax-release-object blk_obj)
(princ "\n\t >> Block does already exist!\n")
(princ)))
(if (tblsearch "block" bname)
T
(alert "Impossible to add block")))
(setvar "attreq" 1)
(setvar "clayer" lay)
(vl-catch-all-apply (function (lambda ()(vla-delete line_obj))))
(vla-regen adoc acactiveviewport)
(vla-endundomark adoc)
(vlax-release-object acsp)
(vlax-release-object adoc)
(or (vl-load-com))
(defun C:d10 (/ *error* acsp adoc appd div-error
len num olderror pl pt pt_list
step util
(or adoc
(setq adoc
(or appd (setq appd (vla-get-application adoc)))
(or acsp
(setq acsp
(vla-get-block
(vla-get-activelayout adoc)
(or util (setq util (vla-get-utility adoc)))
;;; (command "._undo" "_mark")
(setq olderror *error*)
(setq *error* div-error)
;;; (setq bname (getstring T "\nStation block name : \n"))
;;; (make-station bname)
(if (not (tblsearch "block" "Station"))
(make-station "Station"))
(vla-getentity
util
'pl
'pt
"\nSelect line NEAR OF POINT TO START measure: >>> \n"
(if pl
(setq step (getreal "\nEnter step for stationing <10> : \n"))
(if (not step)(setq step 10.))
(setq len (vlax-curve-getdistatparam
pl
(vlax-curve-getendparam pl)
(if (< (distance (vlax-safearray->list pt)
(vlax-curve-getstartpoint pl)
(vlax-curve-getendpoint pl)
(setq pt_list (divplus len step))
(setq pt_list (divminus len step))
(setq
pt_list (vl-remove-if
(function not)
(mapcar (function (lambda (x)
(vlax-curve-getpointatdist pl x)
pt_list
(setq num 0)
;;; (setq num (getint "\nEnter initial station number\n"))
(mapcar
(function
(lambda (x / dr ang att_list at blk_obj)
(setq ang (alg-ang pl x)
ang
(cond ((< (/ pi 2) ang (* pi 1.5)) (+ pi ang))
(T ang)
(setq blk_obj (vlax-invoke
acsp 'Insertblock x "Station" 1 1 1 ang)
(setq att_list (vlax-invoke blk_obj 'Getattributes))
(foreach at att_list
(if (eq (vlax-get at 'Tagstring) "NUMBER")
(vlax-put at 'Textstring (if (< num 99990.)
(strcat "CH" (rtos num 2 3))
(strcat "sta: "
(itoa (fix (/ num 1000.)));<--- changes 1200. on num (typo)
(rtos (- num (* (fix (/ num 1000.)) 1000)) 2 2)
(if (not opt)
(vlax-put at 'Rotation 0))
(vla-update at)
(vla-update blk_obj)
(setq num (+ num step))
pt_list
(if (not (vlax-object-released-p pl))
(vlax-release-object pl)
(princ "\nNothing selected try again\n")
(vla-zoomextents appd)
div-error nil
(prompt "\n")
(prompt "\n *** Type D10 to execute *** \n")
Edited by michaelrezk
Sure I will do that in the future.
Are you able to help me with my lisp ??
How about editing your previous post to include code tags in the present.
  • 4 weeks later...
I'm crazy busy and can't to rewrite it
to your exact needs but hope this
will get you started
 (if
   (vl-position
     msg
     '("console break"
   "quit / exit abort"
    (princ "Error!")
    (princ msg)
;;;  (command "._u")
 (setq cnt 0)
 (while (<= cnt num)
   (setq cnt (1+ cnt))
   lst
 (while (>= len 0.)
 lst
 (angle '(0. 0. 0.)
      obj
        obj
        pnt
(or (vl-load-com))
 wshl
(cond  ((= ans 6)
      (setq opt T))
      ((= ans 7)
      (setq opt nil))
 opt
 (vl-load-com)
 (if (and
 (setvar "attreq" 0)
 (setq line_obj (vlax-invoke acsp 'Addline '(0. 0. 0.) (list 0. (* hgt 12.) 0.)))
 (vla-put-color line_obj acyellow)
         (list line_obj)
        hgt
        atprom
        attag
        "0+00")
;;;    at_obj
   (princ)))
   T
 (setvar "attreq" 1)
(or (vl-load-com))
          step    util
 (or adoc
     (setq adoc
 (or acsp
     (setq acsp
        (vla-get-block
 (vla-getentity
   util
   'pl
   'pt
 (if pl
         pl
     (setq
         (function not)
             pt_list
     (setq num 0)
     (mapcar
   (function
           ang
                 (T ang)
           (vlax-put at 'Textstring (if (< num 990.)
   (strcat "sta: 0+" (rtos num 2 2))
(strcat "sta: "
   (itoa (fix (/ num 1000.)))[color=red];<--- changes 1200. on num (typo)[/color]
           (if (not opt)
           (vla-update at)
   pt_list
   div-error nil
(prompt "\n")
~'J'~
Fixo,
thats absolutely fantastic.
could anyone rejig that code to make the text size slightly bigger and is it possible to have the chainages reading as CH: 12600 rather than sta : 12+ 600 ?
Even if nobody knows how or has time to help me, big thanks still to fixo for the lisp and to this forum as a whole, a complete wealth of knowledge!
Kind Regards
Philip, Belfast
  • 6 months later...
This is a bit late but I have been messing around with this and I almost have how I want it. This is Fixo's code. I am hoping someone can help with the final few bits...
 (if
   (vl-position
     msg
     '("console break"
   "quit / exit abort"
    (princ "Error!")
    (princ msg)
;;;  (command "._u")
 (setq cnt 0)
 (while (<= cnt num)
   (setq cnt (1+ cnt))
   lst
 (while (>= len 0.)
 lst
 (angle '(0. 0. 0.)
      obj
        obj
        pnt
(or (vl-load-com))
 wshl
(cond  ((= ans 6)
      (setq opt T))
      ((= ans 7)
      (setq opt nil))
 opt
 (vl-load-com)
 (if (and
   hgt    1.5 ;(getreal "\nAttribute text height : \n")
 (setvar "attreq" 0)
 (setq line_obj (vlax-invoke acsp 'Addline '(0. -3. 0.) (list 0. (* hgt 2.) 0.)))
 (vla-put-color line_obj acred)
         (list line_obj)
        hgt
        atprom
        (vlax-3d-point '(0 10. 0.))
        attag
        "0")
;;;    at_obj
[color="red"]  (vla-put-rotation at_obj (/ pi 9))[/color]
   (princ)))
   T
 (setvar "attreq" 1)
(or (vl-load-com))
          step    util
 (or adoc
     (setq adoc
 (or acsp
     (setq acsp
        (vla-get-block
 (vla-getentity
   util
   'pl
   'pt
 (if pl
 (setq step 100)
         pl
     (setq
         (function not)
             pt_list
     (setq num 0)
     (mapcar
   (function
           ang
                 (T ang)
   (strcat "Ch " (rtos num 2 2))
(strcat "Ch "
           (if (not opt)
           (vla-update at)
   pt_list
   div-error nil
(prompt "\n")
I am trying to get the text to rotate so that it looks like the image below but I have tried many alternatives but no joy... (see red text in code)
I am also looking to add a suffix "m" to the string.
Would appreciate any help on this...
Thanks
Edited by woodman78
Forgot image
Hi,
I have made progress with this code but I have any issue I can't get over. I have changed the format of the text to read "Ch1000m" for example as opposed to the "Ch0+00m" that was in the original code. But now it runs up to Ch900m and then it gets messed up. Is the code below necessary with the changed format I have. I presume it was to truncate the text for the proevious format. I thought it would be straight forward to just add the number to the text string without doing anything to it...
(strcat "Ch "
   "m"
Could someone have a look and let me know how I can proceed?
Thanks.
