Attila The Gel Posted September 7, 2009 Posted September 7, 2009 Hello, Anyone knows a way to put the total number of a block used in a drawing in the block itself? This is what I'm trying to do: Got this block called 'Border' with some attributes inside it. I Used the block 'Border' 12 times. So I would like to see the number '12' in each block. and when I copy or insert another 'Border' in this drawing. All the blocks must contain 13 instead of 12. And when I delete it must update (with regen or automatically, it doest really mather). Anyone got an Idea? I tried to find it in field but no success. Quote
Lee Mac Posted September 7, 2009 Posted September 7, 2009 This is sort of similar: http://www.cadtutor.net/forum/showthread.php?t=37639 Quote
Attila The Gel Posted September 8, 2009 Author Posted September 8, 2009 Thx, Lee It didn't work because after I select the block, this lisp asks to select a polyline and here's where it goes wrong: Command: BLKUPD Select Block: Select Polyline: > Command: Command: BLKUPD Select Block: Select Polyline: ; error: bad argument type: lselsetp nil could you moddify this lisp to do only the COUNT thing. many thanx, After this I have another question for you. ps: LOL I have a feeling that Acad isn't complete without you . Many thanks for the feedback Hopefully this is more reliable: ;; Block Attribute Updater by Lee McDonnell 06.07.2009 (defun c:blkUpd (/ ins wid hgt bEnt bObj pEnt pObj MiP MaP win num ) (vl-load-com) ;;<< Tag Names must be Capitalised! >> (setq ins "COUNT") ;; << Instances Tag (setq Wid "X-WIDTH") ;; << Width Tag (setq Hgt "Y-HEIGHT") ;; << Height Tag (if (and (setq bEnt (car (entsel "\nSelect Block: "))) (eq "AcDbBlockReference" (vla-get-ObjectName (setq bObj (vlax-ename->vla-object bEnt)))) (eq (vla-get-HasAttributes bObj) :vlax-true) (setq pEnt (car (entsel "\nSelect Polyline: "))) (wcmatch (cdr (assoc 0 (entget pEnt))) "*POLYLINE")) (progn (vla-getBoundingBox (setq pObj (vlax-ename->vla-object pEnt)) 'MiP 'MaP) (mapcar (function (lambda (Obj) (putxdat Obj "LMACUPD" (vl-prin1-to-string (list (vla-get-Handle pObj) (vla-get-Handle bObj)))))) (list pObj bObj)) (setq win (mapcar 'vlax-safearray->list (list MiP MaP)) num (sslength (ssget "_X" (list (cons 0 "INSERT") (cons 2 (vla-get-Name bObj)) (cons 66 1))))) (foreach Att (vlax-safearray->list (vlax-variant-value (vla-getAttributes bObj))) (cond ((eq ins (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos num 2 0))) ((eq Wid (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos (- (caadr win) (caar win)) 2 2))) ((eq Hgt (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos (- (cadadr win) (cadar win)) 2 2)))))) (princ "\n<< Incorrect Selection >>")) (princ)) (defun c:BlkUpdshow (/ gr ent xtyp xval Objlst) (while (and (setq gr (grread t 13 2)) (eq 5 (car gr))) (if (setq ent (car (nentselp (cadr gr)))) (progn (vla-getXdata (vlax-ename->vla-object ent) "LMACUPD" 'xtyp 'xval) (if (and xtyp xval) (mapcar (function (lambda (x) (redraw x 3))) (setq Objlst (mapcar 'handent (read (vlax-variant-value (cadr (vlax-safearray->list xval))))))))) (if Objlst (mapcar (function (lambda (x) (redraw x 4))) Objlst)))) (princ)) (defun BlkUpdr (Reac Args / ins wid hgt blk ss xtyp xval hand pObj MiP MaP bObj win num) ;;<< Tag Names must be Capitalised! >> (setq ins "COUNT") ;; << Instances Tag (setq Wid "X-WIDTH") ;; << Width Tag (setq Hgt "Y-HEIGHT") ;; << Height Tag (if (vl-position (car Args) '("GRIP_STRETCH" "GRIP_MOVE" "GRIP_SCALE" "GRIP_ROTATE")) (if (setq ss (cadr (ssgetfirst))) (progn (vla-getXdata (vlax-ename->vla-object (ssname ss 0)) "LMACUPD" 'xtyp 'xval) (if (and xtyp xval) (progn (setq hand (mapcar 'handent (read (vlax-variant-value (cadr (vlax-safearray->list xval)))))) (vla-getBoundingBox (setq pObj (vlax-ename->vla-object (car hand))) 'MiP 'MaP) (setq bObj (vlax-ename->vla-object (cadr hand)) win (mapcar 'vlax-safearray->list (list MiP MaP)) num (sslength (ssget "_X" (list (cons 0 "INSERT") (cons 2 (vla-get-Name bObj)) (cons 66 1))))) (foreach Att (vlax-safearray->list (vlax-variant-value (vla-getAttributes bObj))) (cond ((eq ins (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos num 2 0))) ((eq Wid (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos (- (caadr win) (caar win)) 2 2))) ((eq Hgt (strcase (vla-get-TagString Att))) (vla-put-TextString Att (rtos (- (cadadr win) (cadar win)) 2 2))))))))))) (defun putxdat (Obj App Data / ent type1 valeur) (setq xtype (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbInteger '(0 . 1)) '(1001 1000)))) (setq xval (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbVariant '(0 . 1)) (list App Data)))) (vla-setXData Obj xtype xval)) (vl-load-com) (if *lmac-Block* (vlr-remove *lmac-Block*) (setq *lmac-Block* nil)) (setq *lmac-Block* (vlr-command-Reactor nil (list (cons :vlr-CommandEnded 'BlkUpdr)))) Quote
Lee Mac Posted September 8, 2009 Posted September 8, 2009 I said it was similar not the solution to your problem. Quote
Attila The Gel Posted September 8, 2009 Author Posted September 8, 2009 I know, but I wanted to try your lisp anyway to see if maybe the count attribute would work. Quote
