hello
i need a lisp to save some screenview which i will call
later (without using command zoom or pan).
Something like
save screenview 1 (2 or 3 ..)
and later
restore screeview 1 (2 or 3 ..).
cheers
My wish is : whith lisp skip this steps
1.view
2.named view
3.- select named view
4.make current
5.ok
Thanks
1.view
2.named view
4.make current
5.ok
Thanks
You are welcome :glare:
didn't you know MacroW, this is TRL (Total Request Lisp)!
hello
Something like
and later
cheers
Autocad can already do this for you.
Research DDVIEW (or VIEW) command.
Steve
hello Steve
whith your suggestion i find the solution
very simply but very powerfull for big drawings
in CUI i made two new buttoms whith command:
1. ^C^C-view
save
2. ^C^C-view
restore
Now is easy to move quickly in the drawing
thanks to all
You're welcome.
And here is a handy routine that will show where all the views are in your drawing.
I am not the author of this program. I don't know who wrote it. The author did not sign his work.
;* DRAW BOX AROUND ALL VIEWS
;* CREATED 5/3/93
(defun DXF (code elist)
 (cdr (assoc code elist))
(defun C:VIEWSHOW ( / tbdata elist)
(if (setq tbdata (tblnext "VIEW" T))
 (while (/= tbdata nil)
  (setq port (getvar "CVPORT")
   vname (dxf 2 tbdata)                     ;extract view name
   Y (* (dxf 40 tbdata) 0.5)                ;view height
   X (* (dxf 41 tbdata) 0.5)                ;view width
  );setq
  (setq CP (dxf 10 tbdata)
   P1 (list (- (car CP) X) (- (cadr CP) Y)) ;lower left corner
   P2 (list (- (car CP) X) (+ (cadr CP) Y)) ;upper left corner
   P3 (list (+ (car CP) X) (+ (cadr CP) Y)) ;upper right corner
   P4 (list (+ (car CP) X) (- (cadr CP) Y)) ;lower right corner
  );setq
  (grdraw P1 P2 7 1)                        ; draws vector
  (grdraw P2 P3 7 1)
  (grdraw P3 P4 7 1)
  (grdraw P4 P1 7 1)
  (setq tbdata (tblnext "VIEW"))            ;* get next view
 )                                          ;* while end
)                                           ;* endif
(prompt " VIEWSHOW Done")
