(defun c:nod()
(command "setvar" "osmode" 1)
(setq ss (ssget "x" (list (cons 2 "NODE"))))
(setq len (sslength ss))
(setq key 0)
(repeat len
(setq ssn (ssname ss key))
(setq ins1 (cdr (assoc 10 (entget ssn))))
(command "zoom" "c" ins1 3000)
(command "move" ssn "" ins1 pause)
(setq key (+ 1 key))
prakash:
Attaching your question to this post was not a good idea. Anyone reading the title of the thread will not be expecting to answer a question about debugging a LISP routine. You should have started a new thread. Maybe a mod will see this and correct the situation.
You should have placed this in the AutoLISP forum.
first things first, localize your variables.
using 1+ and 1- will give much better results when incrementing.
 (setq key (1+ key))
what is this supposed to be selecting?
(defun c:nod()
(setq key 0)
(repeat len
