Little Bandit Posted June 14, 2008 Posted June 14, 2008 I am really struggling to get this dynamic block working and I have run out of ideas - It's a plan view on the flight of steps and I would like to space the risers equally between the bottom and top nosing. I was trying to use array but the value (tread going) stays the same... So I need something thath would work just like divide command. Eventually I need a block with different tread numbers which will be just a matter of creating a few visibility states, just need a little help on this issue first. Any ideas how to deal with this? :wink: Flight.dwg Quote
Strix Posted June 14, 2008 Posted June 14, 2008 I may be being dim here, but why doesn't ARRAY work for you in this instance? (I can't see dwgs on this computer btw) Quote
Little Bandit Posted June 14, 2008 Author Posted June 14, 2008 Because you set this dimension is set in stone in the block editor and it cannot be changed to anything else. Let's say that the step going is 250 - it will work with flights 1000, 1250, 1500 etc long giving you 4 goings. But with a flight being 1200 it will give you 5 goings: 4@250 and 1@200 instead of preferred 5@240 I just hope there is some simple feature in block editor that would allow dividing a line into a few equal sections, or at least copying an element a number of times and space them next to each other. Quote
dbroada Posted June 14, 2008 Posted June 14, 2008 like strix I don't have AutoCAD here to try this but can you... set a distance parameter for each tread as well as the overall height. Chain action all the others and feed them with the distance/n. Either that or a move action in a similar manner. Quote
dbroada Posted June 16, 2008 Posted June 16, 2008 I was almost there with the parameters. You just need move actions on each line. Try this file. By the way, don't call blocks by the same name as the file, you can't insert them easilly. Flight.dwg Quote
Little Bandit Posted June 24, 2008 Author Posted June 24, 2008 Thanks a lot Dave, I've managed to sort this problem out thanks to your help, it all works fine now Quote
ibach Posted February 4, 2013 Posted February 4, 2013 I've tried to comprehend this block for a long time now with no success. Please elaborate how it was made. There is only 2 parameters that i can see and I believe there must be more... Quote
dbroada Posted February 4, 2013 Posted February 4, 2013 there are 2 distance parameters but lots of move actions, one for each line I think. Quote
ibach Posted February 4, 2013 Posted February 4, 2013 Yes, i understand that, but i do not get distance multiplier. How was 0.9 calculated? Oh...I get it... It's different for each line... Quote
dbroada Posted February 4, 2013 Posted February 4, 2013 I can't remember! I think it was just a guess. Possibly I put 10 treads so each one would move 10% of the full stretch. Had I used 8 treads then they would have to have moved 12% each. For that sort of block "about right" is good enough. Quote
ibach Posted February 4, 2013 Posted February 4, 2013 Man, This was brilliant! it works great. You devided 1 with number of spaces and was subtracting that number multiplied with number of spaces from the origin from 1 for each object... Great! Quote
