Hello there ,
I was searching all over the forum but i didnt find, how tu run load macro from command line automaticly.
if i use :
-vbarun
ask me for a name of macro when i tiped in its all Ok then RUn my macro.
but how can i use -vbarun in one line because i want to have shortcut in my button.
itried;:
-vbarun;macro_name didnt work
i hope u understend my problem.
I want to tipe command that execute macro in on line in command line. My macro it loaded in stratup suit.
thx
Wouldn't you have to tell AutoCAD where to find the macro? Something along the lines of -vbarun"C:\Macros\mycustom_macro".
defun it to Lisp Command
(vl-load-com)
(defun c:ttx() (vla-runmacro (vlax-get-acad-object) "D:\Project.dvb!ThisDrawing.tt"))
no this dont work, i tried .
i cant belive that its no simple solution in command line.?
I use the following syntax
-vbaload;"C:/AutoCAD/VBA/filename.dvb;-vbarun;"C:/AutoCAD/VBA/filename.dvb!macroname"
I must note, however; that I put the above into a script file; and then create a toolbar button to open the script file.
ok i tried i have acad 2009 map:
my file is located on :
C:\Program Files\AutoCAD Map 3D 2009\Iztok nastavitve\IzrNiv.dvb
and i do this shortcut but dont work:
-vbaload;"C:\Program Files\AutoCAD Map 3D 2009\Iztok nastavitve\IzrNiv.dvb;-vbarun;"C:\Program Files\AutoCAD Map 3D 2009\Iztok nastavitve\IzrNiv.dvb!izrniv"
macro is run with "izrniv"
where have i misted?
Try changing the direction of the slashes e.g. from \ to /
I have my routines in the ACAD.DVB file, and in that is a short module like this.....
Public Sub Cloud()
Set myObject = New frm_Cloud
myObject.Show
Set myObject = Nothing
End Sub
then on my button I use this syntax
^C^Cvbastmt;cloud;
and all the code is embeded in frm_Cloud
Thank u very much, i cant belive this actually works. I change direction of slash & works perfect, I new that is a simple solution for this.
thx to every one.
:wink:
