Proctor Posted September 9, 2009 Posted September 9, 2009 Hello: Our company has network licsensing set up off the server for several of our users. This morning, I had tried to get in and got the following message: Your application was not able to obtain a license because the FLEXnet licence server manager could not determine where to find the licsening data it needs. Please choose from the following: Specify the license Server System Specify the Licens File if i cancel, i then get this error: A valide license could not be obtained by your network manager. 1200-5.-96 After getting this message, I verified that all the users were not on their machines. I also verified that I could get to the server. Has anyone had this experience before? Thanks Proctor Quote
s_wypych Posted September 9, 2009 Posted September 9, 2009 Looks like you have some issues with your license file, try obtaining a new one to make sure that the feature is correct, make sure that the service is started: -5 No such feature exists -96 License server machine is down or not responding. See the system administrator about starting the server, or make sure that you're referring to the right host (see LM_LICENSE_FILE environment variable). Quote
Proctor Posted September 9, 2009 Author Posted September 9, 2009 s_wypych: thanks for your reply. when i look at help for autocad 09 I don't see LM_LICENSE_FILE. I'll have the admin check the server. thanks again for your help, Proctor Quote
s_wypych Posted September 9, 2009 Posted September 9, 2009 I'm unable to post a link since I'm a new member but if you do a google search on "creating the LM_LICENSE_FILE variable on Windows" you will find the steps to do what you need. You would need to do this on each computer that is using the network license. This is also what you would do if you were to move the license server to another host to point all of the computers to the new host. Hope this helps. Quote
Proctor Posted September 9, 2009 Author Posted September 9, 2009 Hi s_wypych: I googled it as suggested: http://www.fluent.com/support/installation/licensing/fslm_client.htm I'll give this a try and let you know how it turns out. thanks again for your help, Proctor Quote
