Jrose Posted September 9, 2009 Share Posted September 9, 2009 Hello everyone, Does anyone know how to create a countersink on an existing hole. I have a solid piece that has two exsiting holes and i need them to be countersinked. It wont do it. I used extrude and press and pull and it wont work. Is there a way on doing it. Please advice Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 9, 2009 Share Posted September 9, 2009 One way would be to use the CHAMFER command. Pay close attention to the command line prompts. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 9, 2009 Share Posted September 9, 2009 We are talking countersunk and not counterbored right? Quote Link to comment Share on other sites More sharing options...
Jrose Posted September 9, 2009 Author Share Posted September 9, 2009 Yes it is countersunk. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 9, 2009 Share Posted September 9, 2009 Then I stand by my advice. This is what you're apt to see at the command line: Command: chamfer (TRIM mode) Current chamfer Dist1 = 0.0000, Dist2 = 0.0000 Select first line or [undo/Polyline/Distance/Angle/Trim/mEthod/Multiple]: Base surface selection... Enter surface selection option [Next/OK (current)] : Specify base surface chamfer distance: .02 Specify other surface chamfer distance : Select an edge or [Loop]: Select an edge or [Loop]: Quote Link to comment Share on other sites More sharing options...
Patrick Hughes Posted September 9, 2009 Share Posted September 9, 2009 Another option is to create a cone and subtract it from the solid body. The way I have always done it is I draw a circle to the c'sink dia. then extrude using the taper option then subtract. Quote Link to comment Share on other sites More sharing options...
