JONI Posted September 9, 2009 Posted September 9, 2009 I am trying to convert a textline into seperate charakters in order to select one or more separate charakters for the TXTEXP tool has anyone a tip to follow, best regards joni:) Quote
Lee Mac Posted September 9, 2009 Posted September 9, 2009 Perhaps see here: http://www.theswamp.org/index.php?topic=13528.0 Quote
JONI Posted September 9, 2009 Author Posted September 9, 2009 Perhaps see here: http://www.theswamp.org/index.php?topic=13528.0 Hi Lee, thank you for sending this link and have executed the lisp code. I am relieved to see it is possible to break up the textline in to (in your case into 2 parts) It also does the folowing the tekstline splits on the selected charakter the selected charakter is duplicated in both te parts the right textpart is moved to the left what I am looking for to spit up the text completely into separate charakters and they have to remain ontheir original position a way to reach this goal is to disable the duplicating effect(2) disable the move effect (3) so i try to understand the code and alter it Anny tip where to begin? Quote
