Hi
I have unioned several solids together which was saved some days ago
Is it possible to undo the union and return to individual solids, I have exploded the solid but that just turns everything into faces, rather than the original solids
Thanks for you help
There is no ununion command although a few of us might like to have one. What is the variable DELOBJ set to?
Hi Remark thanks for your answer I thought that might be the case, making a copy of everything now before I union anything
My DELOBJ is set to 1, what is this varible for?
Per your AutoCAD Help file:
DELOBJ
"Controls whether geometry used to create 3D objects is retained or deleted."
Anything other than a setting of "0" will delete the underlying geometry that helped you to create the individual solids in the first place.
