Guest looseLISPSsinkSHIPS Posted September 10, 2009 Posted September 10, 2009 Hi, We have this current VBA program to help us with AutoCAD via the use of a template excel sheet. The setup we have created works well; however occasionally we have two drawings per folder, which often results in, two templates excel sheets of the same name, one overwriting the other. In a nut shell dose anybody know how I can set the active drawing name in a variable that our program uses to check for, then if not present that it creates a copy of out template and then saves it as the active drawings file name which was set as the variable This would allow our program to locate the associated excel sheet by name then save it by the unique drawing name and prevent existing excel files being overwritten if in the same folder. Thanks- ;===CODE STARTS HERE=== Option Explicit Private Objexcel As Excel.Application Private ObjWorkbook As Workbook Private Sub Frame1_Click() End Sub Private Sub Frame2_Click() End Sub Private Sub UserForm_Initialize() Dim ObjRange As Range, ObjCell Dim sFolder As String, sDefSheet As String Dim iRow_counter As Integer iRow_counter = 0 'Check if acad drawing is saved… sFolder = fGetDefinitionSheetPath(AcadApplication.ActiveDocument.FullName) If sFolder "" Then ' sDefSheet = "C:\ICT\AutoCAD_2009\Customisations\20090409\20090409.xls" sDefSheet = sFolder & "\" & DEF_SHEET 'Check for precence of Excel-definitionsheet… If Not fExistsDefinitionSheet(sDefSheet) Then 'Copy the standard definitionsheet… Call fCopyDefinitionSheet(sDefSheet) End If 'Opening of Excel... Set Objexcel = CreateObject("Excel.Application") Objexcel.Visible = False Set ObjWorkbook = Objexcel.Workbooks.Open(sDefSheet) Set ObjRange = ObjWorkbook.Names("Artikelinhoud").RefersToRange For Each ObjCell In ObjRange 'Vullen van ComboBox met: Inhoudarticle , stored_count ComboBox1.AddItem ObjCell.Value 'In Column "2" het aantal elementen (stored_count) plaatsen: ComboBox1.Column(1, iRow_counter) = ObjWorkbook.Worksheets(3).Cells(ObjCell.Row, 3) + 1 iRow_counter = iRow_counter + 1 Next 'input of general information... TextBox1 = ObjWorkbook.Worksheets(1).Cells(1, 1) TextBox2 = ObjWorkbook.Worksheets(1).Cells(2, 1) TextBox3 = ObjWorkbook.Worksheets(1).Cells(3, 1) TextBox5 = ObjWorkbook.Worksheets(1).Cells(2, 2) TextBox7 = ObjWorkbook.Worksheets(1).Cells(2, 3) ObjWorkbook.Worksheets(3).Cells(31, 3).Value = "0" 'Set the focus to Textbox1 and highlight the text... UserForm1.TextBox1.SetFocus UserForm1.TextBox1.SelStart = 0 UserForm1.TextBox1.SelLength = Len(UserForm1.TextBox1.Text) Else Call MsgBox("Sla eerst uw tekening op in de projectmap, daarna kunt u kaders toevoegen!", vbExclamation + vbOKOnly, Me.Caption) Unload UserForm1 End If End Sub Private Sub UserForm_Terminate() 'Imitate as it already saved... ObjWorkbook.Saved = True 'Clear memory and close excel… ObjWorkbook.Close Objexcel.Quit Set ObjWorkbook = Nothing Set Objexcel = Nothing End Sub Private Sub CheckBox1_Click() CommandButton3.Visible = CheckBox1 'Vrijgeven van de in te vullen velden... Frame2.Enabled = CheckBox1 ComboBox1.Enabled = CheckBox1 'TextBox6.Enabled = CheckBox1 Label6.Enabled = CheckBox1 Label7.Enabled = CheckBox1 If CheckBox1 Then 'ComboBox recives first value… ComboBox1.ListIndex = 0 'Calls consecutive cloumn from Combobox1… If ComboBox1.ListIndex >= 0 Then TextBox6 = ComboBox1.Column(1) Else ComboBox1 = "" TextBox6 = "" Label8.Visible = CheckBox1 End If End Sub Private Sub ComboBox1_Change() If ComboBox1.ListIndex >= 0 Then TextBox6 = ComboBox1.Column(1) Label8.Visible = True End If End Sub Private Sub CommandButton1_Click() Dim ObjWorksheet As Worksheet Dim ObjRange As Range UserForm1.Hide Set ObjWorksheet = ObjWorkbook.Worksheets(1) ObjWorksheet.Cells(1, 1).Value = TextBox1.Text ObjWorksheet.Cells(2, 1).Value = TextBox2.Text ObjWorksheet.Cells(3, 1).Value = TextBox3.Text ObjWorksheet.Cells(2, 2).Value = TextBox5.Text ObjWorksheet.Cells(2, 3).Value = TextBox7.Text Objexcel.DisplayAlerts = False ObjWorkbook.Save Set ObjWorksheet = Nothing Unload UserForm1 End Sub Private Sub CommandButton2_Click() Unload UserForm1 End Sub Private Sub CommandButton3_Click() Dim objBlock As AcadBlock Dim objBlockRef As AcadBlockReference Dim InsertionPnt As Variant Dim Atts As Variant Dim i As Integer Dim ObjWorksheet As Worksheet Dim ObjRange As Range Dim intNewRow As Integer Dim strNewCell As String Dim ftw As String UserForm1.Hide Set ObjWorksheet = ObjWorkbook.Worksheets(1) ObjWorksheet.Cells(1, 1).Value = TextBox1.Text ObjWorksheet.Cells(2, 1).Value = TextBox2.Text ObjWorksheet.Cells(3, 1).Value = TextBox3.Text Set ObjWorksheet = ObjWorkbook.Worksheets(2) ObjWorksheet.Cells(26, 1).Value = ComboBox1.Text Set ObjWorksheet = ObjWorkbook.Worksheets(4) Set ObjRange = ObjWorksheet.UsedRange intNewRow = ObjRange.SpecialCells(xlCellTypeLastCell).Row + 1 strNewCell = "A" & intNewRow ObjWorksheet.UsedRange.Cells(intNewRow).Value = ComboBox1 Objexcel.DisplayAlerts = False ObjWorkbook.Save Set ObjWorksheet = Nothing InsertionPnt = ThisDrawing.Utility.GetPoint(, "Selecteer het startpunt:") Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(InsertionPnt, "C:\ICT\AutoCAD_2009\Customisations\20090409\template.dwg", 1, 1, 1, 0) 'Sets template scale... ftw = ObjWorkbook.Worksheets(2).Cells(32, 3).Text objBlockRef.XScaleFactor = ftw objBlockRef.YScaleFactor = ftw objBlockRef.ZScaleFactor = ftw If objBlockRef.HasAttributes Then Atts = objBlockRef.GetAttributes For i = LBound(Atts) To UBound(Atts) Select Case (Atts(i).TagString) Case "Onderdeel" ''the name of your attribute Atts(i).TextString = ComboBox1.Text Case "BLZnr" Atts(i).TextString = ObjWorkbook.Worksheets(2).Cells(54, 12) Case "PROJECTNR." Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(1, 1) Case "TEKENAAR" Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(2, 1) Case "DATUM" Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(2, 2) Case "VERD." Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(2, 3) Case "PROJECT" Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(3, 1) Case "STATUS" Atts(i).TextString = ObjWorkbook.Worksheets(1).Cells(4, 1) End Select objBlockRef.Update Next End If Unload UserForm1 End Sub ;===END OF CODE=== Quote
Lee Mac Posted September 10, 2009 Posted September 10, 2009 As Marco pointed out in your other thread - please use [/ code] tags to post your code. See here http://www.cadtutor.net/forum/showthread.php?t=9184 Quote
