How to set the default template | Cad 09
Hello: when i open cad, i would like it to automatically load a template i created. is there a setting that will allow me to do this?
thanks,
Proctor
You'll have to add the command line switch /t along with the template file name to the acad.exe command line associated with your Microsoft® Windows® shortcut icon. For further details consult AutoCAD Help. Search for templates, startup routines.
This will work for all new drawings you start.
I was not aware of that switch...
cool
My tip is probably better for those with multiple projects. Each unique shortcut/template file can be associated with a particular client/project. Your tip probably is the better one to go with in this case.
Thank you both for sharing your knowledge.
chulse, i did what you said and it's loading beautifully now; except,
i noticed that the Global Scale factor setting is not retained in the line type manager. If i do file new and load the template, it retrains this setting. do i need to do something else?
thanks again for your help!
Proctor
