aubtiger77 Posted September 11, 2009 Posted September 11, 2009 Why did this happen? I used the same center line of stairs I used 1/4 round on the one without the error, I used 1/2r on the error. Quote
Noahma Posted September 11, 2009 Posted September 11, 2009 I HATE the stair tools provided in Autocad Architecture. This may be a place where you would need to do a stair from line work. Quote
aubtiger77 Posted September 11, 2009 Author Posted September 11, 2009 Yeah, if I knew exactly why the error popped up I could remove the interferance (that is what causes the error right?) Quote
Noahma Posted September 12, 2009 Posted September 12, 2009 Yeah, if I knew exactly why the error popped up I could remove the interferance (that is what causes the error right?) without having the file in front of me it is very hard to tell what is causing the problem. Your first stair picture appears to have a problem as well. Quote
aubtiger77 Posted September 14, 2009 Author Posted September 14, 2009 yea I guess you are ref to the inside treads are messed up (not all pointing to inside corner) I would like to get the stair function working to be able to make changes to the house later and it adjust with the changes. How do I need to send the file to you? Quote
