Hi,
I know how to extract attribute date from blocks into a text file using attext. I wondering if there is a relatively simple way to do the process in reverse?
Thanks,
ew
Yes, using a program that utilises the read-line function. :)
Should I guide you through making such a program?
Hi,
Thanks,
ew
Hi,
maybee the express-tools are what you're looking for.
With: ATTOUT you can write attribute data to a text-file.
Note that this functions also write the block-handle to the file.
This file can be read and modified by e.g. excel ore any other tab-calculation.
Do your changes, than write it back, make sure it has the .txt extension.
And with ATTIN you can rewrite the attributes to the blocks.
Does this help?
regards
Wolfgang
The attout and attin do exactly what I wanted. Didn't even really notice the Express drop-down menu before.
Thanks,
Ed
