flowerrobot Posted September 12, 2009 Posted September 12, 2009 Good morning I created this last night after realising i had missed a few variables on one of my programs. Run it, Then run the files you want, then run it again. Will output your necessary information and some that isn't important Yes i know its not hard to look threw the setq and see whats defined however on 4k+ lines you miss some sometimes. Use if you like ;| Missed Values Rev 1.0 Created 11-09-09 By FlowerRobot This is used to work out what a program leaves behind. Particualy any varibables missed. |; (defun c:MissedValues (/ TheBigList2 LeadProgn SubFuncts Prognvarible OtherVar) (setvar "cmdecho" 0) (if TheBigList1 (progn (alert "\nThis can take a few mins") (setq TheBigList2 (acad_strlsort (atoms-family 1))) (foreach it2 TheBigList2 (if (not (member it2 TheBigList1)) (cond ((wcmatch it2 "C:*")(setq LeadProgn (cons it2 LeadProgn))) ((member (type (eval (read it2))) (list 'SUB 'USUBR 'EXRXSUBR))(setq SubFuncts (cons it2 SubFuncts))) ((member (type (eval (read it2)))(list 'STR 'USUBR 'INT 'LIST 'REAL 'STR 'VLA-object 'PICKSET))(setq Prognvarible (cons it2 Prognvarible))) (t (setq OtherVar (cons it2 OtherVar))) ))) (setq TheBigList1 nil) (if LeadProgn(progn (princ "\n***** Command Calls **********") (foreach it LeadProgn (terpri) (princ it)))) (if SubFuncts (progn (princ "\n***** Sub Functions **********") (foreach it SubFuncts (terpri) (princ it)))) (if Prognvarible (progn (princ "\n***** Variables **********") (foreach it Prognvarible (terpri) (princ it)))) (if OtherVar (progn (princ "\n***** Other **** **********") (foreach it OtherVar (terpri) (princ it)))) (if (not (or LeadProgn SubFuncts Prognvarible OtherVar)) (princ "\nGood job clean as a whisle\nCreated by FlowerRobot")) ) (progn (princ "\nNow run your programs and then run this program again") (setq TheBigList1 (cons "THEBIGLIST1" (acad_strlsort (atoms-family 1)))) ) ) (setvar "cmdecho" 1) (princ) ) Variables-V1.0.zip Quote
wkplan Posted September 12, 2009 Posted September 12, 2009 Flowerrobot, this work's great! And you posted it just at that moment, I planned to revise some of my code One of these functions that make life easy. Thankyou for sharing it. regards Wolfgang Quote
Lee Mac Posted September 12, 2009 Posted September 12, 2009 Flower, Just a tip, you can check for global variables using the "check" button in the VLIDE Quote
