HP 1220c Printer Pins Settings with AutoCAD 2010
I am using a HP 1220c printer with AutoCAD 2010.
I have installe the printer and it prints but there is no
place on in the plot window to setup pin settings for
various pin widths by color. Is there a way to
do that?
Thank you,
Are you referring to pen settings?
Aren't these normally handled in the ctb / stb file? There's got to be an Edit button for Plot Style right?
I did not find that Edit Button? Normally you do have one edit button on the right but I did not
find it with the 1220c Ink Jet. I used the default windows XP driver to set things up.
Maybe I need a different driver from AutoCAD?
Thank you,
The default Windows driver might be good in a rush but you should download and install the HP driver. I'll have to check my version of 2010 tomorrow for the presence of an Edit Settings button for a plot style. Can't imagine why it wouldn't be.
I'm back in the office today. Checked my version of AutoCAD 2010 Plot window and sure enough on the right hand side under the heading Plot style table (pen assignments) is the drop-down list for the plot styles and next to it is the Edit button. Now the Edit button is not operable until one selects a plot style (ex. - acad.ctb). Please take another look. It has to be there.
