picuscad Posted September 14, 2009 Share Posted September 14, 2009 Hello all I am new to cad and have question: is there way of automaticaly inserting area(text) in to object? I have handreds of residential lots to mark and writing that by hends is litle bit frustraiting. I did search sits for info for past few days, but nothing clear. Thanx for help Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 14, 2009 Share Posted September 14, 2009 One way of doing this is with a LISP routine. There are a few available at the CAD Tips section of the cadalyst magazine website. www.cadalyst.com Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 15, 2009 Share Posted September 15, 2009 This is an example of the type of LISP program I was referring to: http://cadtips.cadalyst.com/create-dimension/label-square-acreage Quote Link to comment Share on other sites More sharing options...
DECHAL Posted September 15, 2009 Share Posted September 15, 2009 Just polyline the region and then use the list command select the pline and it will tell you the area. May have to press F2 button. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 15, 2009 Share Posted September 15, 2009 The OP wants the area to be displayed automatically. Quote Link to comment Share on other sites More sharing options...
picuscad Posted September 16, 2009 Author Share Posted September 16, 2009 Hi Thanks for replying on my question. As I mantion I am very new and lerning. ReMark, you right that is about labeling. I did follow your advice and start learning about LISP. The file is for 2008 I,m using 2010. I cant make to work. Eather I,m doing wrong or is not wqorking with 2010. My gess is me. Thanks for great tips. I will read more and make its work. Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 16, 2009 Share Posted September 16, 2009 It should still work. What kind of problem are you having? Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 16, 2009 Share Posted September 16, 2009 Maybe the LISP routine submitted by fixo in this thread will work. http://www.cadtutor.net/forum/showthread.php?t=15237&highlight=area+label Quote Link to comment Share on other sites More sharing options...
Shibuboss Posted September 28, 2009 Share Posted September 28, 2009 quote; The OP wants the area to be displayed automatically. Use FIELD command FIELD FIELD NAME=OBJECT OBJECT TYPE>PICK POLYLINE PROPERTY=AREA Like this Quote Link to comment Share on other sites More sharing options...
Shibuboss Posted September 28, 2009 Share Posted September 28, 2009 You wil get the area text with mask.just explode it. Quote Link to comment Share on other sites More sharing options...
picuscad Posted September 28, 2009 Author Share Posted September 28, 2009 Thanks for replying Shibuboss. I did use "bo" command and mesuring tool in 2010. I am not shure if that was a lisp file that I inserted or that is implemented in the program. Is there any tutorial on using lisp editor? the best will be one example step by step.I had some trouble to activate the inserted file. Thank you ReMark for pointing to lisp. Thanks Quote Link to comment Share on other sites More sharing options...
