is there a way for me to create sub layers to a layer? kind of like you would in photoshop?
i tried using a layer filter but i dont think that the right way to set it up
No, you can't create nested or "grouped" Layers. You could use Layer Filters, but it doesn't work quite as effectively.
What is your goal with this?
If you want to control layer visibility or lock status of the "sub-layers" by making changes to the "parent layer", then layer filters will work.
Thanks, yes thats what I want to do,
I want to choose a "parent layer" and have layers in that layer that all turn off or on or lock or whatever when I adjust the parent layer
Yea - layer filters can do that.
I have been using ACAD since about 1989, and the only way I can think of creating additional layers is to give them unique names. The menu master will automatically create a layer once you XREF in a drawing. Thus a layer 3 on the parent drawing, may have same attributes as a layer 3 in XREF'd drawing, or a referred to one within that XREF. It can get quite deep, and still be and look the same.
Wm.
thanks for the help!
Make sure you create all your layers and filters in your template drawing(s).
You don't want to have to recreate those each time you start a new drawing.
