Im Trying To Find A Lisp Where I Can Take A 3d Object We Use Cabinets, And Create An Exploded View Of It. Here Is A Before And After View
well, if there is lisp out there to explode an assembly of solids, it is doubtful it will run as you've drawn - since the lisp won't know about what a cabinet is, the sides of the middle cabinet will 'explode' into each side of the end cabinets.
Thats why I only explode one cabinet at a time.
What software are you using for your cabinets?
IM NOT LOOKING TO EXPLODE A SERIES OF CABS. THAT IS JUST THE DRAWING I WAS GIVEN TO POST UP. IF YOU KNOW OF A SUCH A LISP TO EXPLODE SOLIDS, CAN YOU DIRECT ME TO IT. IT DOES NOT HAVE TO BE PERFECT I CAN MODIFY IT MORE. JUST NEED SOMETHING TO GET ME STARTED.
  • 9 months later...
I could also use something like this, there was one that I used a long time ago called 3d burst
Marty
