Hi
i got a problem what should i do if i want to go through that lines when the user select nothing. It would be nice if lCmd.GetEntity(entOpt) returns nothing or something in that case
Dim lCmd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim entOpt As PromptEntityOptions = New PromptEntityOptions("Select Line")
    Dim line As PromptEntityResult = lCmd.GetEntity(entOpt)
Hi
Have a look at PromptEntityOptions properties
If you don't want to allow the user to select nothing, set the entOpt.AllowNone property to false.
If you want to do something in case the user select nothing, set it to true and test if the PromptEntityResult.Status equals PromptStatus.None.
i wrote some code using your advice but somehow it wont work same situation as before
           entOpt.AllowNone = True
           Dim line2 As PromptEntityResult = lCmd.GetEntity(entOpt)
           If line2.Status = PromptStatus.None Then
               lCmd.WriteMessage("you select nothing")
           End If
Hi,
Not certain about VB syntax
           End If
           Else If line2.Status = PromptStatus.OK Then
               ' Do your stuff here
           End If
Here's a more complete C# example
Point3d ucsPt1, ucsPt2, ucsPt3;
PromptPointOptions ppo;
PromptPointResult ppr;
double width = getWidth();
bool loop = true;
ed.WriteMessage("\nCurrent with = " + width.ToString());
do
   ppo = new PromptPointOptions("\nSpecify a point or [Width]<W>:", "Width");
   ppo.AllowNone = true;
   ppr = ed.GetPoint(ppo);
   if (ppr.Status == PromptStatus.Keyword || ppr.Status == PromptStatus.None)
       PromptDistanceOptions pdo = new PromptDistanceOptions("\nSpecify the width: ");
       pdo.AllowNegative = false;
       pdo.AllowNone = false;
       pdo.AllowZero = false;
       PromptDoubleResult pdr = ed.GetDistance(pdo);
       if (pdr.Status == PromptStatus.OK)
           width = pdr.Value;
           setWidth(width);
       else
           return;
   else if (ppr.Status == PromptStatus.OK)
       ucsPt1 = ppr.Value;
       loop = false;
   else
       return;
} while (loop);
When i debug that code the debuger stuck on the line so there is no chance to check the status
i thing that i have to figure out something else ;p
I can't say why it bugs.
I tried this snippet, it works fine:
If the user click on an entity the command line displays "Entity selected"
If the user click an empty space the command line displays: "Pas de sélection" (which means "None selection") and loops : "Select a line: "
If the use right click or type Enter the command line displays "None entity selected".
PromptEntityOptions entOpt = new PromptEntityOptions("\nSelect a line: ");
entOpt.AllowNone = true;
PromptEntityResult line2 = ed.GetEntity(entOpt);
if (line2.Status == PromptStatus.None)
   ed.WriteMessage("\nNone entity selected");
else if (line2.Status == PromptStatus.OK)
   ed.WriteMessage("\nEntity selected");
