How can find in a file (C S V) with VBA?
I have one big rectangle and a lots of little rectangle.
I want to find in .csv file, those one little rectangles filenames, which to be in the Big rectangle (Lower Left point -> Upper right point coordinates Range).
exapmle:
Big rectangle:
lower left point: 848235.6561,446578.4652
upper right point: 849267.9715,447056.4045
CSV file:
columns:
1. filename of little rectangle
2. little rectangle lower left point X coord
3. little rectangle lower left point Y coord
4. little rectangle lower right point X coord
5. little rectangle lower right point Y coord
6. little rectangle upper right point X coord
7. little rectangle upper right point Y coord
8. little rectangle upper left point X coord
9. little rectangle upper left point Y coord
file1;848375.0000;446750.0000;848750.0000;446750.0000;848750.0000;447000.0000;848375.0000;447000.0000;
file2;848375.0000;446500.0000;848750.0000;446500.0000;848750.0000;446750.0000;848375.0000;446750.0000;
file3;848750.0000;447000.0000;849125.0000;447000.0000;849125.0000;447250.0000;848750.0000;447250.0000;
file4;848375.0000;446250.0000;848750.0000;446250.0000;848750.0000;446500.0000;848375.0000;446500.0000;
file5;848750.0000;446500.0000;849125.0000;446500.0000;849125.0000;446750.0000;848750.0000;446750.0000;
file6;848750.0000;446250.0000;849125.0000;446250.0000;849125.0000;446500.0000;848750.0000;446500.0000;
etc....
Can somebody help me?
There appears to be several aspects to this task: Which are you investigating?
If the question is about retrieving the information contained within the CVS then look into the “FileSystemObject”. It can be used to open the file and read it line by line.
Another aspect to the task would be parsing each line of text to sort individual elements. The VBA functions InStr, Split, Trim, etc. should help.
A remaining task would be determining if the smaller is contained within the larger. The important information here, as with the large rectangle, is the lower left and upper right. So if:
If smallLL(0) > largeLL(0) And _
smallLL(1) > largeLL(1) And _
smallUR(0)
smallUR(1)
small contained within large.
smallUR(0)
smallUR(1)
Thx, IF condition is good.
Could You tell me some exapmles about my CSV problem?
What CSV problem is that exactly?
This is the CSV file:
Filename; smallLL(0); smallLL(1); smallUR(0); smallUR(1);
file1;848375.0000;446750.0000;848750.0000;447000.0000;
file2;848375.0000;446500.0000;848750.0000;446750.0000;
file3;848750.0000;447000.0000;849125.0000;447250.0000;
file4;848375.0000;446250.0000;848750.0000;446500.0000;
file5;848750.0000;446500.0000;849125.0000;446750.0000;
file6;848750.0000;446250.0000;849125.0000;446500.0000;
I want to read smallLL(0); smallLL(1); smallUR(0); and smallUR(1) from CSV file.
AND:
smallUR(0)
smallUR(1)
THEN:
I want to get those one filenames (1st column) from csv, where on the IF condition is true.
That is the question.
Problem is done'
   file_name = "D:\items.csv"
   fnum = FreeFile
   Open file_name For Input As fnum
   whole_file = Input$(LOF(fnum), #fnum)
   Close fnum
   lines = Split(whole_file, vbCrLf)
   num_rows = UBound(lines) - 1
   For R = 0 To num_rows
            one_line = Split(lines(R), ";")
            If one_line(1) > largeLL(0) And one_line(2) > largeLL(1) And one_line(3) < largeUR(0) And one_line(4) < largeUR(1) Then
           Msgbox one_line(0)
           Else
           End If
   Next R
