function4 Posted September 16, 2009 Posted September 16, 2009 Hello everyone, I am new to the forum and seeking a solution.. I have a number of thick polylines, and wanted to know if there is a way to outline the lines with smaller lines.. similar to the ink bottle tool in illustrator or flash, if you are familiar.. To illustrate further what I am referring.. A thick single polyline would have four thin lines places around its extent. Anyone have an idea?? Quote
ReMark Posted September 16, 2009 Posted September 16, 2009 Wouldn't you have a problem plotting all these lines clearly? Jeez, five lines (polyline plus a total of four outside lines) seems like an awful lot. What are you depicting? A building wall? Quote
alanjt Posted September 16, 2009 Posted September 16, 2009 Maybe something like this: ;;; Draw outline of polyline wall, based on constant width ;;; Required Subroutines: AT:SS->List, AT:List->Array, AT:List->SS ;;; Alan J. Thompson, 09.16.09 (defun c:Wall (/ *error* #Cmdecho #SSList #Choice #Space #Width #Off1 #Off2 #Line1 #Line2 ) (vl-load-com) ;;; error handler (defun *error* (#Message) (and #Cmdecho (setvar "cmdecho" #Cmdecho)) (and *AcadDoc* (vla-endundomark *AcadDoc*)) (and #Message (or (member #Message '("console break" "Function cancelled" "quit / exit abort") ) ;_ member (princ (strcat "\nError: " #Message)) ) ;_ or ) ;_ and ) ;_ defun (setq #Cmdecho (getvar "cmdecho")) (setvar "cmdecho" 0) (or *Acad* (setq *Acad* (vlax-get-acad-object))) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument *Acad*)) ) ;_ or (setq #Space (vla-get-modelspace *AcadDoc*)) (vla-startundomark *AcadDoc*) (cond ((and (setq #SSList (AT:SS->List (ssget ":L" '((0 . "LWPOLYLINE"))) T)) (not (initget 0 "Yes No")) (or (setq #Choice (getkword "\nDelete original? [Yes/No] <No>: ")) (setq #Choice "No") ) ;_ or ) ;_ and (foreach x #SSList (if (and (not (vl-catch-all-error-p (setq #Width (vl-catch-all-apply 'vla-get-constantwidth (list x) ) ;_ vl-catch-all-apply ) ;_ setq ) ;_ vl-catch-all-error-p ) ;_ not (not (zerop #Width)) ) ;_ and (progn ;; offsets (setq #Off1 (vl-catch-all-apply 'vla-offset (list x (/ #Width 2)) ) ;_ vl-catch-all-apply #Off2 (vl-catch-all-apply 'vla-offset (list x (/ #Width -2)) ) ;_ vl-catch-all-apply ) ;_ setq ;; convert to vla-objects (or (vl-catch-all-error-p #Off1) (setq #Off1 (car (vlax-safearray->list (vlax-variant-value #Off1) ) ;_ vlax-safearray->list ) ;_ car ) ;_ setq ) ;_ or (or (vl-catch-all-error-p #Off2) (setq #Off2 (car (vlax-safearray->list (vlax-variant-value #Off2) ) ;_ vlax-safearray->list ) ;_ car ) ;_ setq ) ;_ or ;; if error on either, delete and move on to next, otherwise, continue (if (or (vl-catch-all-error-p #Off1) (vl-catch-all-error-p #Off2) ) ;_ or ;; delete (progn (vl-catch-all-apply 'vla-delete #Off1) (vl-catch-all-apply 'vla-delete #Off2) ) ;_ progn ;; continue (progn (setq #Line1 (vla-AddLightWeightPolyline #Space (AT:List->Array (append (reverse (cdr (reverse (vlax-curve-getStartPoint #Off1) ) ;_ reverse ) ;_ cdr ) ;_ reverse (reverse (cdr (reverse (vlax-curve-getStartPoint #Off2) ) ;_ reverse ) ;_ cdr ) ;_ reverse ) ;_ append ) ;_ AT:List->Array ) ;_ vla-AddLightWeightPolyline #Line2 (vla-AddLightWeightPolyline #Space (AT:List->Array (append (reverse (cdr (reverse (vlax-curve-getEndPoint #Off1) ) ;_ reverse ) ;_ cdr ) ;_ reverse (reverse (cdr (reverse (vlax-curve-getEndPoint #Off2) ) ;_ reverse ) ;_ cdr ) ;_ reverse ) ;_ append ) ;_ AT:List->Array ) ;_ vla-AddLightWeightPolyline ) ;_ setq ;; join all together (if (zerop (getvar "peditaccept")) (vl-cmdf "_.pedit" "_m" (AT:List->SS (list #Off1 #Off2 #Line1 #Line2)) "" "_y" "_j" "" "" ) ;_ vl-cmdf (vl-cmdf "_.pedit" "_m" (AT:List->SS (list #Off1 #Off2 #Line1 #Line2)) "" "_j" "" "" ) ;_ vl-cmdf ) ;_ if ;; set layer and width (vla-put-layer (vlax-ename->vla-object (entlast)) (vla-get-layer x) ) ;_ vla-put-layer (vla-put-constantwidth (vlax-ename->vla-object (entlast)) 0 ) ;_ vla-put-constantwidth ;; delete original, if #Choice = "Yes" (and (eq #Choice "Yes") (vl-catch-all-apply 'vla-delete (list x)) ) ;_ and ) ;_ progn ) ;_ if ) ;_ progn ) ;_ if ) ;_ foreach ) ) ;_ cond (*error* nil) (princ) ) ;_ defun You will need the following subroutines: ;;; Convert selection set to list of ename or vla objects ;;; #Selection - SSGET selection set ;;; #VLAList - T for vla objects, nil for ename ;;; Alan J. Thompson, 04.20.09 (defun AT:SS->List (#Selection #VlaList / #List) (and #Selection (setq #List (vl-remove-if 'listp (mapcar 'cadr (ssnamex #Selection)) ) ;_ vl-remove-if ) ;_ setq #VlaList (setq #List (mapcar 'vlax-ename->vla-object #List)) ) ;_ and #List ) ;_ defun ;;; Convert list of vla or ename objects to 1 selection set ;;; #SelectionList - list of vla or ename selections ;;; Alan J. Thompson, 05.07.09 (defun AT:List->SS (#SelectionList / #SSAdd) (setq #SSAdd (ssadd)) (mapcar '(lambda (x) (if (eq (type x) 'VLA-OBJECT) (ssadd (vlax-vla-object->ename x) #SSAdd) (ssadd x #SSAdd) ) ;_ if ) ;_ lambda #SelectionList ) ;_ mapcar #SSAdd ) ;_ defun ;;; Convert Point List into Array ;;; #List - List of points to convert ;;; Alan J. Thompson, 09.16.09 (defun AT:List->Array (#List) (vlax-Make-Variant (vlax-SafeArray-Fill (vlax-Make-SafeArray vlax-vbDouble (cons 0 (- (length #List) 1)) ) ;_ vlax-Make-SafeArray #List ) ;_ vlax-SafeArray-Fill ) ;_ vlax-Make-Variant ) ;_ defun Quote
