gilsoto13 Posted September 16, 2009 Posted September 16, 2009 The last lisp I will need, maybe I can use a batch lisp I found already, but I haven´t tested it yet.... It works file by file... as the purgefiles.lsp, it suppose it opens all the dwg files in a directory, a just change them to unitless, save and close. But then I will have to turn all the files I have compiled so far into separate dwgs again and use that lisp to change them to unitless and reinsert them again into compiled dwgs.... Is it possible to change all the blocks in a drawing to be unitless without extracting them from the drawing? Quote
gilsoto13 Posted September 17, 2009 Author Posted September 17, 2009 Hi, You can try Edit_Bloc. Ok, As I told you there... it seems your beautiful lisp will do the work, still not pretty sure it will always work... but after I test it in a few weeks using tool palettes, I will return here and let you know if I got any problem or if it works completely well. Quote
