kwortman Posted September 17, 2009 Share Posted September 17, 2009 I do not know if this is the correct place to post this, but here it is. What are some of the best books to get for learning AutoLisp? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted September 17, 2009 Share Posted September 17, 2009 Here is a list of some free resources http://cadpanacea.com/node/111 Quote Link to comment Share on other sites More sharing options...
kwortman Posted September 17, 2009 Author Share Posted September 17, 2009 Thanks for the help. Quote Link to comment Share on other sites More sharing options...
Coosbaylumber Posted September 19, 2009 Share Posted September 19, 2009 Sort of depends upon which version of Acad you are using. If you are using a Non-current version, do not buy the latest of anything, for may not have all commands you need to get job done available to you. I check out from local library a very old version as commands mentioned there tend to work on more modern systems still. Don't get newer than the system you are aiming for. Wm. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted September 19, 2009 Share Posted September 19, 2009 Technically true, but there has been very little added to Autolisp since visual lisp was incorporated over 10 years ago. Quote Link to comment Share on other sites More sharing options...
Teeds Posted October 12, 2009 Share Posted October 12, 2009 Sort of depends upon which version of Acad you are using. If you are using a Non-current version, do not buy the latest of anything, for may not have all commands you need to get job done available to you. I check out from local library a very old version as commands mentioned there tend to work on more modern systems still. Don't get newer than the system you are aiming for. Wm. Do you have Half Price Books there in Atlanta? Check them out for older CAD books at reasonable prices. I like George Omura's books. Quote Link to comment Share on other sites More sharing options...
