Sorry I'm sure I've seen this question asked before, but now that I want to know it I can't find it.
The question is: if I have a nested object, what is the best way to get the block object that it is within?
thanks!
Hi Steve,
Try this:
   (vla-ObjectIdtoObject
     (vla-get-ActiveDocument
       (vlax-get-acad-object))
         (vla-get-OwnerId Obj))
Also, if using nentselp to get the nested item, look at the last element in the list, after the transformation matrix :wink:
I don't get that bit of nentselp; I use nentsel heaps, but have yet the need to use nentselp with a predetermined point, and when I try it anyway it just returns a similar output to nentsel, ie no matrix. (which is fine at the moment cause I've yet to find a need for it)
You use it a hell of a lot in GrRead loops :wink: -- it will only return the transformation matrix on nested objects :wink:
Yeah I learnt a lot from your usage of grread in Inc Num Suite - until I went through it I always thought you just got the text to attach itself to the crosshairs somehow.
Ahh I see the matrix now. I was only clicking attributes!
Hehe, glad I could be of service to your learning :)
  • 2 weeks later...
just wondering if it is possible to do this with VBA? how?
