Robmercury Posted September 18, 2009 Posted September 18, 2009 Is it possible to insert a cad drawing onto a word document or can you save a cad drawing as a jpeg or word doc. Many thanks Quote
Tankman Posted September 18, 2009 Posted September 18, 2009 You might try prtscr (print screen) then paste into your *.doc file. Open your *.doc M$ Word document and paste. Easy enough. I'm sure there are a number of ways to do this. Quote
CADMASTER1128 Posted September 18, 2009 Posted September 18, 2009 You can also select the object(s) and then paste them on the document. Quote
eldon Posted September 19, 2009 Posted September 19, 2009 You can also export the drawing to a WMF file, and then insert that into a Word document. Quote
skipsophrenic Posted September 20, 2009 Posted September 20, 2009 Could also try the JPGOUT command, and insert the jpeg resulting image that way Quote
