Lazer Posted June 26, 2008 Posted June 26, 2008 I have imported xyz points via excel into a 3d sketch and joined the points with lines and added rads, then I moved the points to get the results I need, anyone know a way to export or quicky extract the new xyz data, I can do this by way of an .IDW and dimensions but I think if I can import points, can I also export them? Quote
Lazer Posted October 1, 2008 Author Posted October 1, 2008 Found the answer to my question, if you have Inventor pro, using the tube and pipe feature you can export the xyz's of the pipework to excel. If you have Inventor suite (without tube and pipe) you cannot export the xyz data. Quote
shift1313 Posted October 1, 2008 Posted October 1, 2008 can you create a data link to an excel file in inventor suite? this is how i find you do this in cad with a BOM Quote
